Question about Karcher 2500 PSI Pressure Washer
Karcher 3300G 4HP Gas
Water inlet point. water leaks at pump inlet..
  • 62 Answers
SOURCE: karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
Posted on May 10, 2009
delgriffith
  • 97 Answers
SOURCE: karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Posted on Jun 19, 2009
  • 56 Answers
SOURCE: How to put oil back into the Karcher water pump
You need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out.) CAUTION: there is some spring tension on the brass head.
Take the brass head off and set to the side on a rag or in a bucket. Dump out whatever oil is in the oil side, making sure not to drop the swash plate or bearing (the pieces sitting in the oil). Fill the oil end with aproximatly 4.5 ounces of Karcher pump oil, (or just 20w 50 weight non-detergent oil). Put the brass head back on and tighten bolts. Put the pump back on the machine.
If this helps please rate.
Bill
Posted on Jan 22, 2010
  • 68 Answers
SOURCE: Hi My karcher k3.65 jubilee is leaking water when
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Posted on Jun 11, 2010
  • 15 Answers
SOURCE: Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Posted on Jul 13, 2010
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Water pouring out from bottom of machine leading to loss of pressure
You will need to remove the main cover and see where the leak is coming from. Could well be either the water inlet or the main pump seals .
May 20, 2010 | Karcher PSI Electric Pressure Washer
No high pressure
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens.
Thanks for using FixYa,
Kelly
May 04, 2010 | Karcher 2500 PSI Pressure Washer
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
I have electric Karcher 330. i did not use for a couple years. tried out today from storage, it seemed the water jet was not strong, so may be the pumper problem or I need to clean the inlet hose? thanks!
the problem is your water seals,
you need to change them,
over time it became dry rot.
have the pump service at the same point.
the springs in the valves can be rusty and brittle..
Nov 21, 2009 | Karcher K2.26 Electric Power Washer
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
Leak when water is filling up with water
First thing to check is the discharge pump inlet hose from underneath the tub to the pump. This frequently vibrates loose enough to allow water to leak out as tub water level increases. Also, this hose may have rubbed against something for some time and developed a hole at the rub point, resulting in a leak. If you are good with a tire patch, you might be able to seal the hole and avoid the cost of a new hose. Make sure the hose is insulated from or pulled away from the rub point to avoid a recurrence of the leak later.
The next most frequent leak point is at the mixing valve at the water inlet where the hot and cold water is channeled into the tub fill. Loose connections or a cracked valve housing will leak water.
Aug 03, 2009 | Washing Machines
Karcher 3300 G water leak out rear of unit from white plasticplug
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
Karcher 2500 PSI Pressure Washer Logo
402 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
