Question about IBM ThinkVision L150p (Black) 15" LCD Monitor
I have IBM Thinkvision L150, 15". when computer is started green light is lighting but LCD couldn't display and it looks blank or black. Ok.
Ibm input signal out of range how can i fix it please
Posted on Jan 20, 2011
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Not sure about spending any money on 15" monitor.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.badcaps.net
Posted on Aug 23, 2010
Monitorwont come on
When i turn on my IBM ThinkPad laptop the battery and power light is on green but the monitor remains black.
Jan 20, 2013 | IBM ThinkVision L170 17" LCD Monitor
I have a IBM L151 LCD monitor which is 2 years old. recently while starting all of a sudden the monitor started displaying images in green color only. Secondly the horizontal images get restricted to half...
-try the monitor on another computer and see if it will be having the same problem
-if same problem w/ a different computer it need repair
-if not the computer that you are using w/ this monitor has a problem w/ the video card --try reinstalling the video card driver
cheers
Feb 25, 2011 | IBM ThinkVision L151 15" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
17 inch IBM Thinkvision
Well... a good way to tested the caps is to used a Blue ESR meter.
Oct 04, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
IBM ThinkVision L150p (Black) 15" LCD Monitor Logo
295 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
