Question about Toshiba 32A14 TV
Cannot find an adjustment on my Toshiba TV model # 32A14 as the picture is too big and runs off the sides and I cannot read the text being broadcast
  • mvessa Aug 20, 2010
    I have a directv remote so I do not know how to adjust it
    President:
  • 1,961 Answers
The problem of your TV concens the voltage there's a problem on the regulator IC you need to replace it...the voltage supply is not stable thats why the picture size of tv is big for the screen..try to replace the regulator you need to open the back cover of your TV the regulator IC is found on the power suppy section. The power supply section is where the power cord is connected.to identify the regulator,it is an IC which mounted with heatsink.replace it and check for open resistors near the regulator also a leak small capacitor near the IC.be very carefull when replacing the IC make sure you unplug it to your wall outlet..you can also bring your tv TO A QUALIFIED SERVICE PERSONEL if you dont have skill in electronic repair..good luck and just post a comment if you have any other question..
Posted on Aug 21, 2010
  • 11,896 Answers
There are some adjustments you may be able to make. Some of these models are factory set and cannot be adjusted. I do believe your may have adjustments on the back or in the menu settings. Here is the manual if you don't have one:
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-32A14-User%27s-Guide-TVRNek56az.html
Posted on Aug 20, 2010
  • Nate Stansfield
    Nate Stansfield Aug 21, 2010
    You will either need to program the tv itself into the remove and press tv, then settings or menu and search for screen adjustment. Or you can purchase an original replacement remove and uses that. Or remove the rear panel of the tv and see if you can find little adjustment knobs.
    or if needed, download the service manual for free here at this site:
    http://www.devicemanuals.com/guide/Telev...
    (just highlight, copy, and paste this think in your internet address bar under a new tab)
  • 4,102 Answers
Hi on your control have you got a button that is the picture of a square with four arrows in it if you have this button the pressing this will adjust the screen.
or do you have a button that has the numbers on 16:9 if you have this button then pressing this will adjust the screen size.
let me know if you dont have these buttons then ill list some others that you may have that will adjust the screen size
let me know ok
  • paul proctor Aug 20, 2010
    Hi without the original remote its just not possible to do as these all for one remotes only offer the basics, i know they have all these buttons on the control but it only offers the basic functions for tellys without the original remote you wont be able to adjust the screen size.
    now getting the original remote could be a problem you could try the well known auction site or the other option you have is to go to your local tv repair shop and see if they have an old remote lying around from a damaged telly they usually keep the remotes in case people ever need one so you might be lucky and get on from their.
    but without the original remote it would be impossible to get it to do what you want to do, i mean you could go through every button on the remote and see if by some slight chance one will alter the size but you would only be guessing by doing that, even in the user guide for that remote it wont tell you how to reduce the screen size.
    so im sorry their is no easy or simple fix you could try all the buttons if you like just press each one once and see what happens but failing that your going to need to get a remote for that make of telly, it dont need to be the same model of telly as long as its the same make it will still work
    let me know if you need further assistance ok
Tv is snowy
Check the antenna connection for firmness first. If it is found OK, check and replace the tuner. It is faulty.
Dec 21, 2012 | Toshiba 32A14 TV
I have a toshiba 32a14 TV and an Auvio universal remote. I can get the remote to turn the TV on and off but I can't get it to change the input to the TV
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
Aug 24, 2011 | Toshiba 32A14 TV
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in...
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
Mar 14, 2011 | Toshiba 32A14 TV
Where are fuses on Toshiba 32a14 TV won't turn on
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
Feb 21, 2011 | Toshiba 32A14 TV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Aug 28, 2009 | Toshiba Televison & Video
2 in. band at the top of my Toshiba 32" Tv is distorted. No adjustments worked. Thought it was the change to dtv, but this is the only tv in the house that's affected.
well is the band white or black and clapsing it may be in the vertical curcit also does it do it w/out dtv converter box hook it back up the way that it was see what happens sorry
Apr 03, 2009 | Toshiba 32A14 TV
Dead
Put it on the rubbish. Thanks
Aug 27, 2008 | Toshiba 32A14 TV
Toshiba 32a41 has power, no pic or sound
please clarify it are you getting light? power button will not turn it off means what.
Sep 25, 2007 | Toshiba 32A41 32" TV
Toshiba 32A14 TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
