Question about Mtd Garden
My mtd model # 13AN772G729 will not go forward or back.
  • 24 Answers
Are both of the drive belts on?
Posted on Aug 20, 2010
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 | Mtd Garden
My mtd yard machine bogs down in the tilled /cultivated dirt. the belly support is only less than 2 inches to the bottom of the tires! when I till the next row the tires just turn freely and I have to...
Sounds like a depth adjustment or a leverage problem.
Check your manual to see if you are able to lower the tines to a deeper position.
There usually is also a handle adjustment to raise the handle to get more leverage. (Not all Models) By pulling back on the handle it forces the tines into the soil and raises the tires. This allows the tines to agitate and do the work while at the same time walking the machine forward. When you push up on the handle the rubber tires provide traction and forward movement and less digging on the tines.
Method: Possibly by allowing a little space between passes your wheels won't hang up in the previous dead furrow. You can then go back over the skipped spaces or cultivate from the other direction and a criss cross pattern.
Best wishes,
TF
Jun 02, 2011 | Mtd Garden Tiller (Mtd)
MTD MODEL 13AB652F729 came to a complete stop by itself while running. It felt as if I had stepped on the brake. I lifted the rear of the tractor and found that the rear wheels won't turn while the...
If it stalled while mowing long grass the drive system will need resetting. Do this by starting the mower, while in neutral place the speed lever in the highest speed setting then let you foot off the brake/clutch then back on. Place in forward and you should have drive restored. Regards Phil.
Apr 23, 2011 | Mtd Garden
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Need instructions to replace main drive & transmission belts. Mower will not go forward or backwards. MTD model # 13AN601H729
Before you go trying to replace the belts, did you shut it down the last time you used it while the transmission was in a HIGH range?
If you did, restart it, put your speed lever back in the same or higher position with the F& R shifter in neutral, let out on the clutch/brake pedal until it takes up the slack, then pull the speed lever back into lowest speed, push in the clutch/brake and put it in PARK. Shut of the engine and then restart, it should be back to normal operation now
Sep 07, 2009 | Mtd Garden
Garden Logo
116 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
