I have a older model trane we had thnder storms yesterday and the breaker tripped hit the breaker but i get no cold air
  • 139 Answers
Check the fuses at the disconect prob blew them they are outside by the unit prob a grey box follow the wires from the condensor
Posted on Aug 21, 2010
Air conditioner hums does not work
Check your breakers if they've tripped the condenser will try to come on but the fan won't blow
Jun 14, 2015 | Trane Air Conditioner Accessories 1 Gal....
Trane condenser tripping breaker
Check amperage of compressor on start up. If amps are lower than the breaker -- bad breaker
Aug 29, 2014 | Heating & Cooling
Goodman GPH1336H21A
If the power failure was due to a storm the blower motor may have shorted out. Check that the breaker for the inside unit has not tripped.
Jul 05, 2014 | Goodman Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Trane air conditioning wont start after storm?
Check breaker n panel box & power switch by a/c unit
Jul 14, 2012 | Heating & Cooling
After the storm we lost the power and keep tripping the breaker is there a fuse in system
does the unit come on at all meaning doew the indoor fan come on . it appears that the compressor took a hit but its hard to tell. from what you tell me . let me know
Jul 22, 2011 | Heating & Cooling
Central air conditioner unit comprssor doesn't come on i suspect a lightening storm did something while we were away
check main power breaker, and reset breaker on unit, otherwise lightning storm would have nothing to do with units problem other then power surge, which would trip a breaker. Hope this helps, Thanks Mikemc1bean.jpeg
Jun 23, 2011 | LG Heat cool Window Air Conditioner
The window unit has ran for 3 years never tripped the breaker now it only trips the reset button on the cord does not trip the breaker when i reset it it works great for a while it stormed the night it...
well they do go bad was it eclectic storm it might have fired it. but make sure the unite is clean both front and back if have air compressor blow it out,Ok! hope this helps Paul
Jul 06, 2009 | GE AVX10AD Air Conditioner
AC tripping breaker.
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
May 25, 2009 | Goldstar GW-HD5000 Window Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
