Question about GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator
Fridge not cooling enough... Repairman said that the board has gone bad but everything works fine other than the fan...Was he just trying to sell me a $400 board or what?
    Champion:
  • 245 Answers
Sounds like either your evaporator fan is bad, or your condensor fan is bad underneath your fridge or your condensor lines are dirty. I would check those things out first.The evaporator fan is located in the freezer behind the back panel. You should be able to here and feel the fan. Good luck!
Posted on Aug 20, 2010
  • dcapinegro Aug 20, 2010
    The fan in the freezer is not working, but does that mean the board could be bad? Where can I order a fan for this? Thanks.
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
I have a Bosch Refrigerator at my church that is not cooling on the Refrigerator side, it is a Model # B20CS50SNW /02. I am an electrican but not an applance tech. The blower fan for that side is not...
Generally the fans use line voltage, but if you have a controller board and are getting 12 Volts this would be the correct voltage. The problem is the fans. You will need to replace these fans and defrost the freezer and fridge. When the evaporator coils have frozen overdue to insufficent air flow then no fan will be able to cool the fridge. So make sure that once you replace these fans you get a good defrost for at least 8 hours. Unless you use a hair dryer or heat gun to speed up the process. You will find that these fans are about $52.00 each and trying to repair or fix one will only result in a second repair.
Aug 04, 2010 | Bosch Refrigerators
Fridge is not holding proper temp but freezer is still working
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The timer can also be called an advance defrost control.
Also make sure to check the heater coil for resistance. If that is open then it is the problem.
By doing a search for "appliance parts" you can find the part you eed easily.
Enter the model number of your unit and then select the part you need from the parts menu.
You will have it in a few days.
It is best to check a couple of sites to be sure you get the best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana French Door fridge not cooling
you have a problem here
you need to get the secondary defrost kit installed
it is not the jazz board
unless he is not programming it right aftwer install
but check your back wall for frost
if you have frost you have an airflow issue
whats happening is the door is being left ajar even a 1/16 gap is an issue
when hot air enters the unit fromn the gap it condenses on the diverter behind the freezer wall
after a few weeks it builds up enought o cause problems
there is a kit you can get that will divert electrical heat to the diverter and keep it warm enough to defrost it there by never having the issue again
Oct 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator Logo
120 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
