Question about LG 47 in. Flat-Panel LCD HDTV
Aspect ratio is set on "Just scan" but picture is still to lage to fit screen. thois problem persists no matter what is selected, 16:9 4:3 etc. All zooms on TV have been turned off. Any idea's ? I have a cable box...... Thanks, Gary
taran_2005
  • 10515 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
Hey,
Folowing is the link for the service manual for FLU 1911 s :-
http://www.retrevo.com/s/Polaroid-FLU-1911S-TVs-review-manual/id/2894bh033/t/1-2/
I hope it wld help u :)
Posted on Nov 25, 2008
SOURCE: LG 32'' LCD TV aspect ratio self switching
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Regards,
Massimo Moruzzi
Posted on Nov 30, 2008
SOURCE: 32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Posted on Jan 12, 2009
  • 3 Answers
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
  • 458 Answers
SOURCE: edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Posted on Jun 30, 2009
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
Adjust screen for Maxvent Plasma TV
do you mean you want to adjust the picture settings?. you can select compatible aspect ratio like 4:3 or the 16:9 to fit in the screen.
Aug 11, 2012 | Televison & Video
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Our TV has only 2/3rds visible. The 1/3rd is black and is not using full screen view. The aspect ratio is set at 16:9. this is also showing up on the DVD mode. No matter what you select for aspect ratio it...
Y Main board has failed.
Y Main controls vertical lines in the picture. Plasma TVs have x2 of these Boards. One for left and one for right. It sound like one of these has failed. Loose connections may also result in the symptom you reported
Jul 20, 2009 | LG 50PG30 Plasma HDTV
TV picture doesn't fit in screen no matter what the setting
Ok, so I think I have your solution :)
You're actually my first when it comes to this site, so hopefully this fixes your problem!
Step 1 - Turn off the cable box, but leave the TV on
Step 2 - On the front of the 8300HD, press the "guide" button and the "info" button at the same time
Step 3 - Choose "HD" for High Definition, or "SD" for standard definition. (Sounds like you're HD?)
Step 4 - Choose the aspect ratio 16:9
Step 5 - Choose "progressive scan" if it asks you.
Now press the "power" button on the box, does that fix it?
Apr 03, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
The bottom and top of the picture are being cut off
Check your remote for a "zoom" or "picture size" button. Press this button to adjust the size until everything fits back on the screen.
Please take a moment to rate this solution a fixya if it's helped with your problem. Thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
LG 47 in. Flat-Panel LCD HDTV Logo
1,208 people viewed this question
Computer Repairing
Computer Repairing
