Question about LG LH-D6230 System
LG LH-C6230 Home Theater is not working. After inserting the DVD/CD its shows that CD Error and the compartment is opeing automatically. Had check with the Local Service Shop ( Warrenty is already Expired long back) and they advised to replacement required for DVD/CD compartment which they dont have because the model is old. Could you please help/support us from where we can rectify /repaire the same. I am residing at United Arab Emirates, Abu Dhabi.
SOURCE: 'Where can I get an LG optical pick-up for the LG LH-D6230 DVD player?
You only need to clean the laser nad the problem is gone:)
Posted on Feb 20, 2008
SOURCE: LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Posted on Mar 23, 2008
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
  • 3 Answers
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Posted on Nov 26, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
Tip
LG LH-D6235 DVD Manual Download
Download LG LH-D6235 Home Cinema System Manual
Would you like to review the features of the LG LH-D6235 Home Cinema System?
Have you lost your LG LH-D6235 Home Cinema System Users Guide?
Would you like a digital, searchable, pdf version of the LG LH-D6235 Home Cinema System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the LG LH-D6235 Home Cinema System documentation.
I hope that helps.
____________________________________________________________________
LG LH-D6235 Home Theater Region Free Fix
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
Jan 15, 2014 | Audio Players & Recorders
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
Tip
LG LH-D6235 Region Free Fix
Follow these steps:
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
Lg surround sound system shows blocks on screen or no images but lots of sounds.hard time reading disks, working on and off...
This problem is due the dvd problem may also take place but some times wiring loose connection may happen. so kindly check with this and if you still found problems please feel free to contact us, to get the solution.
Mar 30, 2009 | LG LH-T754 Theater System
DISC ERROR MESSAGE
Usually it helps a lot if you take off the upper case of the DVD player (7 screws) and search for the lens of the DVD/CD. Clean it with alcohol or terpentine or something like that and it will probably work afterwords. Good luck.
Jun 22, 2008 | LG LH-C6235 System
LG LH-D6230 System Logo
350 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
