Fuse Blowing Repeatedly
Hello, my samsung rear projection tv stopped working. I replaced the lamp, still nothing. I then learned about the fuse. I found the fuse it was blown. I replaced it and when I tried to turn the tv on it powered up in standby mode. Then when I went to turn it on the fuse exploded. I replaced the fuse again and also used a surge arrester in the power point. The fuse still blew. Can you help me please mate? I would be extremely grateful. Thanks very much.
Regards
Darrin - Australia
    Genius:
  • 1,074 Answers
If you are not a tech have one check your tv,the voltage regulator is shorted and needs to be replace.this component can be found in the power supply.i do not have the part number and location as i have no schematic for this set.
good luck
Posted on May 05, 2008
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
Samsung TV: HLP4663WX/XAA Lamp Code: BP96-00826A(P) No picture . . . no light from lamp On/Off Switch: ''lamp'' and ''Stand By Temp'' Should I replace the lamp?
hello am rico, no. first check your power supply, because lamp has nothing to do with power. more like it you goona have power supply problem. if you need more help, feel free to call at 602-810-7149 anytime.
Jan 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
I just replace the lamp w/housing and color wheel on Samsung HLN467W--now the lamp light is flashing and the temp light is red, why?
Hello you may also have a bad thermal fuse which is located above or to the side of the lamp housing, IF you are getting 6 blinks and then pause for 3 secs then 6 again, the thermal fuse is open and needs to be replaced.
Oct 24, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My sony wega kf-50we620 has no picture...lamp light on
Yes, you'll need to replace the bulb. Since no electronics stores stock rear projection bulbs, you'll need to look online for the actual lamp. You can get by for awhile by removing the lamp and blowing on it to remove any dust. I did this with mine, but the fix only lasted a few weeks. I was able to find a new lamp online for around $100 and my wife was able to replace it without issue.
Aug 25, 2009 | Sony Grand WEGA KF50WE620 Television
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Oct 23, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Sony kdf-60xs955, rear projection tv
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Jun 19, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
