Question about GE Spacemaker JVM1640SJ Microwave Oven
No power. There is power to the receptical. - GE Spacemaker JVM1640SJ Microwave Oven
    Champion:
  • 245 Answers
Check your breaker and test the recepticle with an inexpensive plug tester. From there I would call a licensed electrician.
Posted on Aug 20, 2010
Model NE-9970. After a storm-caused power outage, why does the microwave have no power to the control board?
Usually the microwave is plugged into a ground fault protected outlet. Push the buttons on the receptical and power should come on. The ground fault may be above your counter top and protects the plug your microwave is pluffed into.
Nov 18, 2015 | Microwave Ovens
No power
If there is no power and you have checked the wall receptical where it plugs in, then it has blown a fuse inside the microwave oven. Because there are lethal voltages that will cause death I suggest a qualified repairman to assess the item.
Mar 27, 2012 | KitchenAid Microwave Ovens
Jvm2070 no power
Providing the wall receptical is working, the main fuse in the microwave oven has blown, common cause a bad door switch.
Mar 14, 2012 | GE Microwave Ovens
The power just went off. tried unplug for 20 secs and plug again. tried the braker and plug. still nothing
Plug a lamp into the wall receptical, if it works! the main fuse in the microwave has blown. Unplug, and remove the top "several screws" check under the keypad and follow wires to the circuit board, look for a silver rectangular capacitor, take a screw driver and short the two points to remove any residual voltage. Now look for a small fuse "clipped" pop with screwdriver and replace with the same current rating, assemble unit because lethal voltages are present when powered on.
Mar 04, 2012 | Panasonic NN-T990SA Microwave Oven
No power, power at receptical,20amp fuse good
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 14, 2011 | Whirlpool MH7140XF Microwave Oven
I have power going to microwave from electrical receptical, but the microwave has no power, will not show nothing tme, etc
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | Kenmore Microwave Ovens
My Jvm1750sm1ss ge microwave just quit working no lights or anything the is power at the receptical
unplug microwave and replug to see if it will restart Call tech to determine prob if small problem... then order manual and how to fix micro. ,If determined it is the magnatron..It is advisable to seek tech help and not do it yourself unless you are qualified to work on the micro.
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No power
No power at all? ... gotta ask, assuming it is a counter top model...if you plug something else into the outlet does it work? That way 'we' know there is power getting to the unit. If something else works in the outlet, (assumng a 2 outlet receptical in the wall) plug the microwave into the same outlet as the other item that worked. If still no power, you probably blew the internal fuse in the microwave.
That said, they are there for a reason, chances are there is another problem in the unit that needs to be fixed. An appliance repair man reently told me they are only expected to live 5 or so years anymore... pitiful....
Peace,
Mar 06, 2010 | KitchenAid Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
54 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
