Question about Rival CF156 Deep Fryer
I heated the fryer without oil so I am assuming I ruined the heating element because it doesn't heat. My question is ca I get another heating element?
  • 864 Answers
I would have to say no i cant find online rival selling individual parts for these models. But i wouldnt assume the heating element is blown. If you feel you can take it apart look and make sure that all the wires are properly connected to the heating element and that none of them shorted out.
If thats not the case then there isnt much you can do as this is not a commercial/industrial model. I know no one likes to hear that.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Posted on Aug 20, 2010
Does the heating elements for my 16 cup deep fryers sit directly in the oil?
Heating elements should not be in direct contact or near a combustable materiel. Heating element should be in free space and away from touching the pot base. If you have oil touching your heating element you wil have sponsteous combustion and create a fire. In your case have someone qualified to disassemble your unit and clean the chamber where your heating element is located, have the pot verifed for possible leaks. Note: someone may have spilled oil over the edge of the pot which ingressed to the bottom of the fryer where your heating element is located. Good house keeping with your appliances is essentiel for your safety.
Good luck and be aware of fire.
Aug 15, 2017 | The Kitchen Appliances - Others
How to remove heating element
In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
May 24, 2015 | Cuisinart Kitchen Appliances - Others
My kenmore deep fryer turns on but wont heat
When you say turns on I assume you are reading voltage at the heating element, if so it is bad. It could also be the thermostat.
May 26, 2014 | Cuisinart CDF-100 Deep Fryer
Can you soak heating element on a butterball electric turkey fryer?
Most heating elements are indeed submerged in oil and for that reason I would not think it would affect your unit, however I do not normally work on home model products. I am a commercial restaurant equipment dealer, working on commercial products only. Trying it out would tell with within a few minutes whether it's going to work or not? Any other questions, I would find the 800 number or website for that company and ask them directly. Sorry I couldn't be more help to you, but I just don't know that much about home model stuff.
Susan Restaurant Equipment Outlet, Cincinnati, OH
Nov 15, 2011 | Kitchen Appliances - Others
It will not turn on
Hi Woodman22191,
I suggest that you do a couple of visual inspections first before doing anything drastic. Here's a list of things that you should check :
- Is the magnetic cord assembly properly attached to fryer socket ? - Is the electrical cord assembly plugged into electrical outlet? - Is the Power ON/OFF Switch is set to ON? - Is the Heating Element Assembly correctly assembled? Make sure Heating Element Assembly is properly installed on base. - Are you using too much or too little oil in the pot? Make sure that you use the recommended amount of oil in the oil pot.
If these things above does not fix the problem, you may need to Reset the Fryer. - Press Reset on Heating Element/Control Panel by inserting a paper clip or any small pointed object into the opening labeled RESET.
I hope this solves the problem. All the best to you. Good luck.
Dec 06, 2010 | Hamilton Beach 35030 Deep Fryer
Light does not come on, nor does it heat up
Some fryers have safety switches on the heating element, this is so they can not be turned on when not properly installed into the unit. Check to see if there are grooves or slots on the side of the fryer which correspond to grooves or slots on heating element. Then slide the heating element into the slots on the fryer.
Safety switch in most cases can not be seen and can not be disengaged by hand. The heating element must be installed properly in order to work. It may be illustrated clearly in the owners manual.
Do not try this with out oil in the Fryer!!
Nov 14, 2008 | Kitchen Appliances - Others
Rival CF156 Deep Fryer Logo
119 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
