Hoover Electra 540 Dual Spin Washing Machine top left drawer
I "inherited" this machine a while ago. It's old, Australian made and goes well. I can't work out the function of the compartments in the washing product drawer. Of course no manual and I can't get any sense out of the Hoover UK site, I do not have a "product code" as it is not on the back as far as I can see and not inside the porthole either where they say it is.
There are three compartments. Left and right are troughs and a small boxy middle one with a blue "post" which is probably for fabric conditioner. What is the exact function of these troughs, please?
  • Palifox May 04, 2008
    Thanks -I suspected that it was something like that.
  • Washing Mach... Master
  • 744 Answers
Hoover Electra 540 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Do this model have a filter and is working with cold water only
Posted on Nov 26, 2009
Its simple. The trough on the left is cold water, and the tough on the right is hot water. If you wash with hot of warm water put your washing detergent in the right trough if you was with cold water only put your detergent in the left trough. As you said the small one in the middle is for softener or conditioner.
Posted on Nov 03, 2008
left-detergent
middle-fabric softner
right-bleach
Posted on May 03, 2008
Door does not unlock after spin cycle on hoover electra 530 dual spin washing machine
the door interlock is aok i think the vacuum switch hoze is blocked up with grub
clean the whole hozes inside with pipe cleaners
i get them from the local home brew shop and ebay pipe cleaners
and use a calgon tablets or bleach mixed with soap for a full washing soap too clean all the pipes
and esp the pump!!! and clean it out
take it out brake in half pull out the viens and clean with like the green jaggy rought cloths ...
youll find the pump vien unit comes free of the bearings .
reasemble
or if your not confident to do it
show this post too the tech you employ
and tell him this is a ~£40 max job
Mar 05, 2015 | Hoover Washing Machines
Please help me I don't know how to put ll the
more info needed like how many pipes. however you should have 3 pipes . 1 red , 1 blue and 1 other .
the red connects to your hot water supply
the blue connects to your cold water supply
and the other pipe should come from the bottom of the machine and is your waste which will need to be connected to the sink waste or another waste pipe.you must ensure the waste pipe is fitted otherwise when you run the machine it will empty on to the floor
Oct 02, 2012 | Washing Machines
Electra 535 Dual Spin - I`m trying to discover what the capacity of this machine is, the manual supplied with the machine gives all spec.s apart from its size. ie is it 6, 6.5 or 7. kilos...
From what I remember, the 535 is a 5.5 kg machine. The best way to load any front loader is to have the tub full but not packed. Its the safest. As for weight capacity, due to Australian Standards testing, machines have to state what load they will handle with a certain volume of water and power usage, but any front loader, load it up but dont pack the clothes in and you will have the best efficiency. By the way, the clothes are measured dry weight..
Jul 31, 2011 | Hoover Washing Machines
My Hoover Front loader is leaking water from underneath the machine. It is NOT the taps..I believe it could be the rubber seal just inside the door of the machine, as it has a hole in it. Could this be the...
If the hole goes right through the seal it could be the cause, but I am inclined to think it is a vent hole for the seal and that a leaking seal will come out on the front panel. Remove the machine back and check the pump seals and the hoses, it is more likely those at that age. Take care, there may be live terminals and connectors inside the back of the machine when the power is on.
Mar 27, 2011 | Hoover Washing Machines
Is there a lint filter on a hoover electra 540 washing machine
Did you get a manual with machine? answer is in there. if not google your units name and model number with the word manual and it should come up
Mar 12, 2011 | Hoover Washing Machines
Hoover Electra 540 Dual Spin. Are hoses still available for this model? I require the hose from the filler to the drum and also from the drum to the pump.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
You can give them the diametre (inner/outer), length, you can of course get it, substitutes, at your local shop also.
Mar 06, 2009 | Hoover AAA160 Front Load Washer
Drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Jan 21, 2009 | Hoover AAA160 Front Load Washer
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Washing Machines Logo
552 people viewed this question
Top Washing Machines Experts
