Question about Bosch 24 in. 6SGS53C02 Free-standing Dishwasher
Suddenly the water isn't getting hot in our Bosch dishwasher. There' snever been a problem before!
  • 54 Answers
SOURCE: Bosch Dishwasher
check screen at water valve...
Posted on Jun 25, 2008
SolutionGuy
  • 331 Answers
SOURCE: Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Posted on Mar 13, 2009
  • 21 Answers
SOURCE: Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Posted on Jul 20, 2009
  • 457 Answers
SOURCE: my bosch dishwasher is not producing hot water,
THE WATER GOING INTO MACHINE IS NOT HOT. LET WATER RUN UNIT IT IS HOT THEN START THE MACHINE. HEATER ONLY FUNCTION IS TO MAINTAIN THE HEAT , IT DOES NOT GO FROM COLD TO EXTRA HOT
Posted on Feb 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher runs long.
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours, though many not included here still suffers from the same problem...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning and obviously no "extra" heat ( aside from the water inlet temp. ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 03, 2011
Does a bosch dishwasher sps53e have cold water feed only
Most dishwasher should be hooked up to a hot water line. They do recommend that you run hot water in your sink before you start running your dishwasher.
Feb 25, 2015 | Bosch Dishwashers
Does my Bosch SHU43C06UC/17 dishwasher have a hot water element in it? Our kitchen tap water does not get very hot, and before I hook up the dishwasher I want to make sure it will have water hot enough to...
Hi.
Your dishwasher should never be connected to a hot water tap.
Every dishwasher has its own Heating element. If you connect it to a hot water tap you may eventually damage the inlet valve which has sensitive plastic components in it and may even void your warranty if your installation manual suggests Cold water connection only.
Regards Sam
Oct 06, 2013 | Bosch 24 in. SHU30 Built-in Dishwasher
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
Dishwasher will not run, gives a message "E-24"
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Feb 12, 2012 | Bosch Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I have a 5 year bosch shu43c05uc & my dishes aren't clean any more? i've cleaned the bottom lint container & it still isn''t clean? does my dishwasher need repair?
You should be able to get several more years out of it with a good maintenance call or a Do It Yourself routine on checking your water inlet valve. spray arms, internal filters.
Mar 08, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch 24 in. 6SGS53C02 Free-standing Dishwasher Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
