Question about Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator
Water accumilates in the bottom of the freezer in the morning there is a thin sheet of ice on the bottom of the freezer
  • Maytag Master
  • 43,501 Answers
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
Leaks water overnight,thin sheet of ice on bottom of freezer section,side by side,
This is most likely due to a defrost drain issue. See the attached link for information on this and how to clear it up. Let me know if it was helpful.
Water leak
May 28, 2010 | Maytag Refrigerators
I have a Kenmore refrigerator 596.71864101 that develops a thin sheet of ice on the bottom of the freezer (which is on the bottom) even after I shut of the water to the ice maker. It seems to be dripping...
You are right about the source of the water. It is coming from the evaporator coils. When the freezer goes into defrost mode, it melts the ice on the coils. The water is supposed to run out of a drain below the bottom of the floor of the freezer. It is common for these drains to freeze shut. If you clear this drain and remove all of the ice from the pan under the floor of your freezer, your problem should go away.
Feb 05, 2010 | Kenmore Refrigerators
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
