Question about Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47
Kohler toilet k4530 20521 12/14/90 sound of water going into bowl
  • 653 Answers
SOURCE: raising water level in the toilet bowl.
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Posted on Apr 04, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
manhandy
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
  • 297 Answers
SOURCE: Toilet - 14 inch rough in
no you must move the toilet flange on the floor,and then get a 10 in. rough in toilet.
Posted on Jul 14, 2009
  • 4340 Answers
SOURCE: I have the Kohler model
Something is leaking. Your description sounds like tank water is slowly leaking and then the tank refills. You really need to use Kohler brand parts, as others pieces seem to not work well.
Posted on Sep 22, 2010
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page: http://www.us.kohler.com/general/contact.jsp
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
Jan 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
I have the Kohler model 703 one piece toilet. It runs once about every ten minutes. It sounds just like a flush but nothing happens in the bowl. Any ideas?
Sep 20, 2010 | Kohler Toilet - One Piece with Ingenium...
Toilet keeps running... it's making the sound a toilet makes right before it shuts off - like an air sound.
your float on the toilet inside the bowl is possibly no good what you need to do is replace it by getting a standard kit at homedepot or lowes or any near by plumbing shop first shut off water behind bowl then unscrew hose that conects to bottom of the bowl then you will see one more nut take that off then replace with new going backwards with the same steps also you will need to empty bowl to do this by holding down handle while the water is shut off
Aug 19, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Kohler - Toilet - One-piece - Gabrielle - K14257-WS-47 Logo
679 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
