Question about Goodman CKL60AR60 Air Conditioner
What is the capacitor size for a Goodman AC Modle 3K 36-18
  • 144 Answers
It is a canister that wires plug into it produces more voltage to supply the system their are start caps and run caps. this part is tested by a uf reading
Posted on Sep 11, 2010
What capacitor part is for goodman manuf. A.C. modelCk18/1B s/n **********7
Value should be printed on side of capacitor expressed in microfarads. The symbol is a uf. The u has a long tail on it. That is how you pick up a replacement.
Aug 15, 2016 | Goodman Heating & Cooling
How many tons is a goodman inside coil modle u-61
tonnage is based on condensor size. not enough info on coil to tell.
May 19, 2014 | Goodman Heating & Cooling
What size capacitor for a cpke42-1b
You will need to call Goodman. I rely can't imaggin how the compressor can start with out a start run capacitor.
May 15, 2014 | Goodman CKL60AR60 Air Conditioner
What could be the problem with the goodman a/c if you turn it on and you hear a hummin but the fan dont turn on
capacitor? will hum if contactor pulled in but no ac power. will hum if contactor pulled in and bad capacitor. depends on how lowd the hum is. loud hum prolly equals bad capacitor
Feb 26, 2013 | Goodman CKL24AR24 Air Conditioner
What type of capacitor comes with a 5 ton Goodman Air conditioning unit model number CK60-1C
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
Jun 21, 2010 | Goodman CKL60AR60 Air Conditioner
WHERE THE CAPACITOR ON A GOODMAN 5 TON AC UNIT
Remove the cover where the power goes into the outside unit. In there should be the capacitor, circuit board, and contactor. There may be 2 capacitors or just one that works for the fan and compressor. If there is just 1 it will have 3 terminals and it is important to hook the wires back right so label them and write it down if you need to.
May 24, 2010 | Goodman CKL60AR60 Air Conditioner
I HAVE A GOODMAN CK-36-1A AC AND THE FAN IS NOT WORKING. WAS TOLD TO REPLACE THE CONDENSER CAPACITOR AND IF THAT DID NOT WORK REPLACE THE THE CODENSER FAN MOTOR. THE COMPRESSOR COMES ON BUT SHUT DOWN WHEN...
Goodman unit you can use a 1/4 hp or 1/3 hp cond. fan motor but it does sound like a cap. Replace cap first. Its very easy to do just open up panel and replace the silver bullet with terminals out the top. It will say on the side what size it is like 40uf 5uf or something like that. Thats most likely your problem. Russ
Aug 14, 2009 | Heating & Cooling
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
97 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
