Question about Kenmore 63942 Dryer
Hello, I've got a Kenmore 80 series dryer Model: 110. 96584110 that is tumbling but not heating. What would you recommend as a next step short of buying a new dryer. Should I change the heating element and thermostat? Thanks!
  • 744 Answers
Check for lint clogging first. Pull the unit away from the wall and look to see if there is an excessive build up of lint at or near the discharge vent or into the vent line. Clean as needed. If it's really clogged you may have to remove the back cover.
If no joy, then check for a bad thermostat. There should be two. They are located on the discharge vent near the dryer exhaust blower. You will have to remove the back cover of the dryer to get to them. Check the stats for continuity. MAKE SURE the power is off before working on the dryer.
It's much more likely to be on of the two items listed above, but if the dryer isn't clogged and the stats are both good, check the heating element.
Posted on Aug 20, 2010
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
Kenmore 80 series not heating. vent is good and clean and air is moving forcefully outside.
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Nov 26, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore series 80 gas dryer tumbles no heat
Yes. If the thermal fuse has no continuity, then the fuse is bad. Replacing it should get you back in action, barring any other defective items like the heating element, etc. Best wishes.
Aug 17, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series HD+ dryer will not heat. dryer runs and tumbles fine just no heat
Check thermal fuse behind the dryer by opening the back cover.Fuse is on the air duct.
Jun 18, 2009 | Kenmore Dryers
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Kenmore 63942 Dryer Logo
437 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
