Whatever system I plug monitor into it displays a box " not opt mode requires 1024 x 1080 6ohertz I have removed video driver reinstalled works fine with all other monitors. will not even boot up windows - message comes on as soon as PC starts
  • 85 Answers
What massage u got tell me
Posted on May 03, 2008
My laptop shows that its on but the screen is blank no light
Greetings
First you have to check your memory first, if you have an extra memory or RAM replace it then try to turn it on. If its still the same no display, try to plug the CRT,LCD or LED monitor to your VGA port commonly on the side of the laptop, as shown below by pressing the FN key and the F5 button to switch the monitor to CRT,LCD or LED monitor. After you tried these procedures and still doesn't change at all. You have to bring your computer to a computer or to the service center of Acer. Because they have to repair your motherbaord, like replacing some of the capacitor on your cpu bridge area or reheat your south or north-bridge circuit.859bbf9a-e2c8-4160-9edd-6c0287f402da.jpg 9c95ede9-6d28-45e5-956f-3a4720027c7f.jpg
Jul 07, 2014 | Acer Aspire E1-510-28204G50Dnsk 15.6 LED...
Unable to install on screen display after windows 7 installation
What do you mean unable to install on screen display? Are you saying your screen is blank?
Maybe you need to reinstall the video drivers.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If you are saying that the system boots up and everything seems to be running except the screen is blank then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 14, 2012 | IBM LENOVO - ThinkPad R500 - Genuine...
Unable to load on screen display on lenovo r500
May 14, 2012 | IBM LENOVO ThinkPad R500 - Genuine Windows...
I try to change my computer monitor settings but they won't change. why?
You should be able to click Start/Control Panel and then look for Display or Display and Personalization.When it opens up select the Settings tab and click on 1 to select your lcd display. There should be two numbers 1 for lcd and 2 for external monitor.
You might be able to do it by keystrokes on your keyboard. Normally you can Press and Hold the FN function key at the lower left portion of the keyboard, then hit the key that toggles the display. The key that toggles the display will normally have LCD/CRT on it or it might have the icon of a display. It toggles between 3 modes (LCD Only, CRT Only or Both LCD and external CRT).
You could try reinstalling your Video Drivers but you would need to be in Safe Mode With Networking to give you internet connectivity. When it boots up open your internet browser and download and install the Video Drivers.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If all fails you could do a System Restore to a Restore Point (date and time) before you started having the problem. Don't worry, System Restore does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected).
Click Start/Programs/Accessories/System Tools/System Restore then select a date and time (Restore Point) that was before you started having problems.
May 09, 2012 | Dell Dimension C521 PC Desktop
At first Ithought it was my monitor, so I went and bought a new monitor. Hooked up the new monitor and monitor is still blank. It turns on Windows XP and then a little box comes up "sleep mode"...
Have your tried booting into "Safe Mode" ? minimal video drivers are used, allowing you to go in to
  • Control Panel
  • System
  • Hardware
  • Device Manager
  • Display Adapter , Uninstall your old driver
  • Reboot , this allows yours system to clear the registry
  • Re-install video drivers for new card
Feb 24, 2011 | Computers & Internet
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Jul 06, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Cannot get CPU to recognize Tatung LCD Monitor
When you reinstalled the drivers, did you reinstall the video card drivers? The drivers for your video card should be sufficient to power your display.
Mar 24, 2009 | Computers & Internet
I have a Samsung Syncmaster 740NW, using XP, I cannot change the screen resution using the "settings" tab in display properties to anything other than 800X600 pixels
Sounds a lot like your display driver is not installed properly. What is the make of the video card? It should display that information above the slider.
If it's blank or unknown on plug and play monitor (or whatever monitor you have), then the video driver is not installed properly. That's a whole other question which will require more information.
Aug 24, 2008 | Computers & Internet
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
