Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I keep getting an error code F1. There is NO explanation in the manual just call a technician....what can i do to check things out? the wassher begins to fill up with water then stops abruptly flashing the F1 error message. I hit cancel/pause and the message goes away. i am then able to get the washer going. However now it is starting to increase the amount of times the F1 code appears like when it starts to rinse
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%#
Posted on Sep 21, 2010
I have a Singer Futura Quartet SEQS-6700 sewing machine. Keep getting error code 16, but there is no explanation in the product manual. Can you help?
Generally the error message is due to "some" electrical overload. It settles itself most times by turning off the sewing machine for a few seconds to allow complete shut-down and then turning it back on. It the error message returns, it is best to visit your qualified local technician.
Nov 07, 2014 | Sewing Machines
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
I turn power on my Brother SE 270D sewing macine and it immediately startrs giving beeps and the F1 error code, what is that and how to solve?
Call Brother and ask them 1-877-276-8437, I looked through your manual online at their site, and could not spot it either. Maybe, we are blind, LOL. That is crazy for them to have that thick manual and no explanation as to what F1 stands for.
Nov 22, 2010 | Sewing Machines
Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
&%YR
May 11, 2010 | GE Profile JTP56 Electric Double Oven
%#$TEF
Mar 18, 2010 | GE Profile JTP56 Electric Double Oven
My machine stops and blink f1
unfortunately the only thing you cud look for in errors in washing machines is whether the door is closed properly or not. beyond that u will hav to look for a service technician the codes can be deciphered only by a service technicians of that particular company as error codes differ from company to company. The only thing I cud say is that there is a malfunction of one of the components in the machine sorry but if u hav the manual see if the error code u mention is listed in the manual
Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting error code F1 and F3 on my matag oven... the darn thing keeps beeping too
f1 error code is a defective touch pad or control board.. the f3 error is a shorted temp sensor.. you might be better off just getting a new oven. check on price of parts first.
May 14, 2008 | Maytag Kitchen Ranges
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
267 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
