Question about Microtek C593 15" Flat Panel LCD Monitor
I was given this monitor(C 593) without a voltage cord - what do I need to look for?
  • 11,361 Answers
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
TFT8000 18.1 in. Flat Panel LCD Monitor: Was given the monitor with only a video cord. Pow...
It may have failed Backlight inverter circuits. You just need power AC cord and the VGA cable to attach to the PC VIDEO card. Try it on another PC.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Compaq TFT8000 18.1" Flat Panel LCD...
Which STR used inpower supply of ibm7095-593 monitor
this model is known for problems os you have one or two things you can do; 1. get a new lcd monitor orget that one fix at the cost of a new one.
May 03, 2009 | Computers & Internet
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Power cord
the HP part number for the US power cord is
8121-0740the part number for the US power adapter is
5189-2852
Aug 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor loses power randomly.
Is your monitor a CRT or LCD type. For CRT type information follows. In most cases your simptoms indicate a problem with the High Voltage or blanking circuits. Caution the High voltage can be as much as 40,000 volts and even unplugged from the wall the picture tube can continue to hold voltage (enough to hurt you). Do you here a snapping sound from the back of the crt. If you do the high voltage is shorting out and the protection circuit is turning off the high voltage. If you do not here sparking another possible cause is a faulty capacitor in the protection circuit or the flyback (high voltage transformer). Unless you are educated in electronic circuit repair this one is probable beyond your curren knowledge level. You can try taking the back off and cleaning out all the dust, but remember to stay away from the red wire that goes to the picture tube. Use only non metal cleaning tools. Good Luck
Nssms
Jul 21, 2008 | Gateway FPD2275W LCD Monitor
1501 power supply
The screen comes standard with a LiteOn power supply, 12v 3.3amp
Dec 21, 2007 | HP Compaq 1501 15" LCD Monitor
Microtek C593 15" Flat Panel LCD Monitor Logo
46 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
