Question about Tecnik TKC8525 Double Oven
My TKC 8525 double oven fitted with gas grills on top, sometimes trips the fuses and when running the gas grills the oven comes on automatically. Canyou suggest what thefault could be and how it can be masetooperate correctly? e-mail - petermitch@btinternet.com
  • petermitch Aug 21, 2010
    Please see my comment above.
    Peter Mitchell.
    Somewhere on this web page Imade my comments. Are they lost? Essentially the work you recommend can only bedoneby certifiedelectricians in UK andIamsure you suggestion willbemost useful. Will revert when any work carried out, Regards Peter
  • 3,083 Answers
One other tech at this site stated that the oven control goes through the main clock...so if the main clock is set to "auto", the oven will come on at certain times. Make sure the main clock's set to "manual", and see if that helps. Disconnect the power and turn it back on, then reset the clock, and that shoud do it.
Other than that, the clock/timing circuit or main controller circuit could be totally shorted, but that seems too obscure.
Hopefully this will helps.
Posted on Aug 21, 2010
    Genius:
  • 1,478 Answers
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors. Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Take care.
Posted on Aug 20, 2010
How or where can I get bottom oven door seal tkc 8525/2 No058587098
Any appliance store should be able the help you with that. Not a big box store. An appliance store.
Nov 13, 2014 | Tecnik TKC8525 Double Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Grill broken only part working
You need to replace the complete element
Dec 24, 2008 | Tecnik TKC8525 Double Oven
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Tecnik TKC 8522 or 8525
hi if you contact tecnic should be in the manual they should be able to supply you with a new facia for the cooker good luck.
Mar 06, 2008 | Tecnik TKC8522 Electric Double Oven
Tecnik TKC8525 Double Oven Logo
174 people viewed this question
Top Tecnik Ovens Experts
Craig Butler
Craig Butler
Raj Patel
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
