Question about Nikon D70s Digital Camera
Getting message "this card cannot be used", but it is a card I have used before. I get the same message with all of the cards I have.
  • cabateman Aug 20, 2010
    Thank you. also, on the screen, where the number of photographs is usually shown, is flashing HR.
  • 10,515 Answers
I love this error as it has created a Havoc. Search and you would find hundreds of unsatisfied customer's.
This is a repair error code. Card is fine. This is a common problem in this model. Unfortunately, no lawsuit. Anyway, back to the problem, there are few things you could try to fix this issue. ( these are all hit and trial. These might fix the camera for a certain time ).
1. Pressing the reset switch at the bottom of the camera body.
2. Take the CF card and again insert it.
3. Make sure all the pins in the slot is fine. I have seen some times,if the pins are bent, you are bound to get this error.
Most of the times, it is a problem with main circuit board.
Good Luck!!
Thanks!!
Posted on Aug 20, 2010
  • Nikon Master
  • 17,130 Answers
Try the carrd on your PC card reader for any issues, if not format and reinsert once again. If the same error comes in then it is possible that the contacts to the memory card is faulty, worn out or damaged. Have you by any chance tried to put in any other cards or reversed .If so the contacts may be moved.
You will need to check into the card reader slot toconfirm or replace this card slot.
I suggest that you call and confirm or visit the nearest Nikon service centre to take help than to let the camera be tampered.
Get estimate and decide.
Good day
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Memory card error
Make sure you're using SD cards. If the cards are larger than 2GB then they're actually SDHC cards. While they fit in the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Aug 05, 2012 | Pentax Optio MX Digital Camera
Memory card error
I keep getting a Card Access Error message on my Sharp VE-CG40U, what could be causing this?
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
May 03, 2012 | Sharp VE-CG40U Digital Camera
Brand new camera keep getting message "card error" can you tell me why i keep getting this message
Two possible reasons: 1. The card needs to be formatted in the camera to work. 2. The card may be to large a capacity for this model camera. For example, if the camera can use up to a 2GB card and you try to use an SDHC 8GB card, you will get "card error" so check your manual.
Jul 05, 2011 | Vivitar ViviCam X029 Digital Camera
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
Getting the following message, "Card not
Try "Formatting" the card again and see if it doesn't work. You should be able to do this in the camera through the Menu choices. If it still doesn't work, then something went bad with the card and it will have to be replaced. Moisture and just a small electrical shock such as from your own static electricity while holding a card can possibly cause this to happen.
Nov 23, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
I have had my Intova IC 600 for almost a year. Recently I was getting a "Card Error" message. I replaced the card, but the message won't go away. I have tried to reset the defaults, but the message won't...
You probably just need to format the card in the camera to get it to work. This will erase the card so download any pics first using a card reader if necessary.
Mar 28, 2010 | iClick Intova IC800 Digital Camera
I keep getting a card error message when I turn the camera on
what kind of card are you using? If your not using SM media card you might consider buying one..but before you get a new one try to borrow from someone or try to put a different memory card and see if it still shows a card error message...
Jul 06, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Getting format card message
2 ways you can do it...
- you can do it in a card reader...(right click the card reader icon at your PC and select Format)
- or you can use a 3rd party shareware program called Pocket Mechanic to do it for you...
Dec 06, 2007 | Kodak EasyShare Z612 Digital Camera
Nikon D70s Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
