Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Need manual for defrosting instructions - Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
  • 8,197 Answers
May I get the make and model # so I can help you more.
Posted on Aug 29, 2010
Do you have free a manual for singer sewing machine model 7422?
Singer has the manuals for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the Singer Advance 7422 is http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf . If you would like a printed version, try here: http://www.sewingpartsonline.com/instruction-book-singer-7422.aspx .
I hope this helps.
Nov 14, 2015 | Summit SCF-630 Commercial Chest Freezer,...
INSTRUCTIONS on Using Vaseline and hairdryer heat to help create a better seal on Kenmore upright manual defrost Freezer gasket??
cleaning the gasket first is a must . warm soapy water .then check the seal gasket with a magnet .before greasing it with vaseline,unless this unit is OLDer than I am it is a magnetic seal but they do split and need replacing .
Oct 17, 2015 | Kenmore Freezers
Defrost iceking ch 102 instructions
Some are automatic, some are not. Need Make and Model.
Oct 15, 2014 | Freezers
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
My freezer has gone into what seems to be a defrost cycle but is on day 4. Is this normal? It is staying at 0.2 degrees C
This freezer has a manual defrost control on it, comes this way. Also has defrost drain hose in the front with a wrap around evaporator and condenser coil. A unit should only defrost for about 45 minutes to remove any build up, 4 days indicates it is stuck in defrost. It doesn't show the cross over temp to F from C on my chart at 0.2 degrees. You should have a defrost control that you are able to put into defrost your self. Look around the back or anywhere there may be a removable panel or it should show you where to put this box into defrost since it is manual and not automatic.Give it a turn in the direction and watch to see what happens. It may go into defrost again and come back out on its own and freeze properly. If it continues to stay in defrost, you will need to replace this timer. Take all of the info and pick one up at a appliance parts house that will stock it. Draw you a diagram so you dont forget how you removed it and that will make it much easier to install. I will also send you a link about this freezer next. It will be coming to you after you get this. Keep me posted.
Shastalaker7
Mar 31, 2010 | General 14.8 cu. ft. Electric Chest...
I lost the instructions to defrost my new upright freezer
just turn stat all the way up, or unplug from wall.
less there is a manual defrost button.
Sep 14, 2009 | Freezers
Cannot turn off defrost mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work.if it is staying in defrost their is a manual stem you have to turn.Tom
Jun 18, 2009 | Freezers
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Defrosting
Hi, Is the compressor running? How old is it? Is the compressor clicking off and on like it is trying to start but can't?
I want to try ans help, just need some answers.
Vic
May 16, 2009 | Kenmore Freezer 20.6 cu. ft. Manual...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
41 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
