Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
How do I level the mowing deck. I do not have a manual. At the moment when I put it in the highest setting, it barely come off the ground.
  • 490 Answers
I found the owner's manual at the manufacturer's website. Here is the link:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
It takes a minute to load, but then you have the whole manual at your fingertips. Hope this helps:)
Posted on Aug 20, 2010
How can I raise the mower deck on my Troy-Bilt Bronco 13YX78KS011? On the highest setting (5)it mows very short. After mowing only once on setting (3) the pulley has ground a groove on the adjustment
I hope you have a warranty.. I did have a mower that I had to removes some shims from between the engine and the frame to keep the belt from being misaligned. but of course that has nothing to do with the deck height.
Nov 16, 2014 | Garden
Craftsman zts 7500 50" deck is there anyway to adjust height on this mower? at the highest level it cuts way to short and i have tons of grass blowing out the side cant hardly mow unless i mow about e
The range of the mover cut should be between 3-3/4" to 1-1/2".
If you are not getting these heights then the mover height mechanism may be jammed or broken. Use lubrication as instructed in the manual.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0803095.pdf
Sep 01, 2014 | Garden
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
Sharp turns mower didgs in ground or on unlevel ground
If you have the owners/operators manual that came with the mower, it will have instructions on how to LEVEL the mower deck. That sounds like your problem. Deck wheels would greatly help also by stabilizing the deck so it doesn't bounce and "float" so much while mowing.
Jul 12, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
May 03, 2010 | John Deere Tractor 1020, 1520, 1530,...
The deck tilts down forward so the guide wheels are always in contact with the ground. how can i level the deck so it raises and lowers equally front and rear?
a mowing deck is suppose to be lower in th front than the rear usually 1/2" to 3/4" difference however if you need to adjust your deck you can go to www.deere .com and search for your owners manual and the procedures will be in the owners manual
Aug 29, 2009 | John Deere Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Mandrel on right side has broken 3 times have only done 7.3 hours
It sounds like your blade is hitting the ground when you are mowing.If you have high spots in your yard the blade will cut into the ground and the mounts on the mandrel will break. Make sure the mower rake adjustment is set correctly,the mower blade should be level or a maximum of 1/4 inch lower in the front.This adjustment is done with the adjuster bolt that runs from the front of the mower to the frame under the muffler, it may have one or two rods connecting the mower at this point. Also make sure the wheels are set down far enough so they can prevent the deck from scalping,they have five different mount holes,if they are up in the highest they will not do anything.Unfortunately these mower mandrels will not take a lot of punishment and they can break when the blades contact anything like dirt or tree roots. Your ultimate action may be just to mow the grass a little higher to keep from scalping. Hope this helps.
Aug 04, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
