Question about Refrigerators
I have a Maytag Trilogy fridge freezer - model: G32026PEKB The compressor blew and has been replaced but does not cut out Advice please Nigel Winter
  • 828 Answers
If the compressor runs continuously is everything freezing? If the compressor is running and it is not cooling the problem could be a refrigerant leak in the system. Visually check points where new compressor was brazed into place. Any sign of oil at these points indicates a leak. How long ago was the compressor replaced?
Posted on May 03, 2008
My Maytag refrigerator is not cold at all...any advice?
Check make sure the air flow under the refrogerator is not blocked Frank Walton Tamaqua Pa.
Jan 13, 2018 | Maytag Refrigerators
We have a whirlpool american fridge freezer leaking gas the engineer has been out 3 times , firstly we were told that the motor had blew one of the boards was replaced didn't work then motor repla
No! Gas leakage is only caused by bad joints, stress cracks or holes in the pipework. Also bad seals on the compressor.
The only 'motor' is the condenser fan motor. The other sort of motor is the Compressor.
I would cut your losses, ask them to recover all the parts installed and give you credit and buy a new refrigerator. The reasoning is that their diagnosis did not fix the problem.
Jan 13, 2018 | Whirlpool ET1FHTXM Top Freezer...
My refrigerator does'nt defrost
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 30, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
How reliable is the Maytag Trilogy fridge freezer?
Hi Brooke,
Maytag Triology is the one of the good option available in the market.However requires maintenace of this product as reviews rating of this product is not good.
Aug 23, 2011 | Maytag Microwave Ovens
Does not cool it is like it is stuck on defrost makes a high pitch buzzing sound What could be wrong
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
Jul 27, 2011 | Maytag Refrigerators
Fridge stopped working/ freezer still works great?
the freezer works ok..this is where the cooling unit is..so, if the freezer works ..its not blowing or allowing air to flow into fresh food area..if its missed its defrost..it will not allow air to go into fresh food area and you need to remove panel and defrost coils ..or see if blower is working...check for bad heater or defrost thermostat or what controls defrost ie timer or board
May 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
170 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
