Question about Motorola Cell Phones
Often when I try to make a call I get call restrictions sims -34 what is this and how can I get rid of it.
    Genius:
  • 1,478 Answers
I will advice you remove the sim card from your phone and insert it in another phone, see if you the problem occur, if not, it means the problem is the sim tray on your phone. The sim try on your phone is bad, you will need to clean the sim tray on your phone and but back the sim to see if it fix the problem. I not, replace the sim tray.
But if the problem persist on the new phone you inserted your sim card, it means the problem is with the sim card, you will need to get a replacement sim for your sim.
Take care.
Posted on Aug 20, 2010
Can't use phone, call out, get call restriction 34 message
see the link. Contact your telco.
Long after the fact, but in case someone searches for "call restrictions -34" info, as I did....
I called Tracfone Exec Resolutions Staff at 1-800-876-5753 and was helped very professionally by an agent. We found that the phone still identified with the first SIM card that I had installed, rather than the replacement I had installed in order to be in AT&T/Cingular network rather than T-Mobile. Within 15 minutes, he had walked me through entering one string of codes and a few parameter checks, turning on/off phone twice...I was then ready to go with a fully functioning Tracfone.
So, this issue can be resolved. Not sure if others problems will also be related to the SIM card issue, but it is a possibility. Hope this helps someone.
tracfone call restriction 34 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
Aug 9, 2009 - Why do I get tracfone call restriction message 34? ...tracfone call restriction message 34? I have a Motorola Tracphone with sufficient minutes, service days and charge bars. I have received call restriction 34 messages infrequently, but they have ... Question about TracFone® V170 Cellular Phone. 1 Answer ... Can't use phone, call out, get call restriction 34 message
12 Mar 2018
SOLVED: Tracfone call restriction 34
8 Sep 2014
tracfone restriction 56 Questions & Answers (with ...
13 Mar 2011
Why does my safelink phone say check call ...
4 Aug 2010
More results from www.fixya.com
Check Call Restrictions -34 (?!) - HowardForums
https://www.howardforums.com/showthread.../1529955-Check-Call-Restrictions-34-(-... May 23, 2009 - 13 posts - ‎12 authors
I got this message today - "Check Call Restrictions -34" - on a recently activated T101g which has only ever had 1 SIM (ATT). It also showed an icon for "out of your service area". I turned off the phone and waited 15 minutes. When I turned it back on, it had a signal & worked fine. I turned it off and back on a ...
What does the message--check call restrictions -34 mean and how do ...
https://www.justanswer.com > ... > Cell Phone Technician > Tracfone Problems May 25, 2011 - Hi, thanks for using. Technician's Assistant: that message appears if you have blocked any specific number of your contact list. It is not a Cell Phone problem, it's just the telephone Company is restricting the calls to your phone. You will have to contact your telephone company to check the Call restriction ... https://www.howardforums.com/showthread.php/1529955-Check-Call-Restrictions-34-(-!)
Mar 12, 2018 | Cell Phones
Can't use phone it says it has no sim.# n restriction 34 can u heip me
only your service provider can assist you with this . call them with someone elses phone .
Feb 12, 2016 | LG Cell Phones
Restriction 34
plug into computer and refresh software, check sim card, for corruption . replace it.
Jan 11, 2015 | LG Cell Phones
Restrictions 34
call carrier corrupt sim card??
Jan 11, 2015 | Cell Phones
PHON SAYS RESTRICTION 34 WHEN I TRY TO USE IT
Contact your ASP (administrator service provider) like VODAFONE as you will not be able to use this sim card at any other phone except your password Or you can put your puk code more than 10 times then sim card will be purged finally you can make sim swap and it will work normally
Dec 05, 2012 | Cell Phones
The Samsung tracefone won't let me call out it's
Call restrictions are due to SIM card problems (Maybe you are using the wrong network, or your SIM card is not being detected by your phone) Another possibility is that your cellphone is restricted by the service provider. Why don't you give them a call?
Oct 25, 2012 | Cell Phones
How to get rid from sim restriction?
it seems your phone is locked. you need to unlock your phone. you can unlock your iphone using remote unlocking service. there are many providers now a days who help in unlocking mobiles. you can get this service from Simpleunlocking.com
Feb 17, 2012 | Apple iPhone Computers & Internet
My phone is restricted
Hi to get rid of this problem you can unlock your Nokia by unlock codes..try Mobile-Unlocker.com and get restriction code and unlock your mobile so that you can use other provider's SIM in your unlocked Nokia..
Feb 11, 2012 | Nokia X2 Mobile
I have a Motorola W260G Tracfone and I'm getting a "Restricted Number - 34" message all of a sudden. What is this about?
Had a similar problem on my V170. Remove the battery and the sim card. Using a q-tip dampened (not dripping wet) with rubbing alcohol, clean the metallic side of the sim card and allow to air-dry, then wipe once more with a dry q-tip. Do the same for the metal terminals in the sim card slot if visible. Go ahead and clean the battery's contacts and the ones in the phone while you're there. Put it all back together and try again. This will fix most sim-card problems as long as there's no physical damage.
Good Luck
Jim
Aug 03, 2009 | Motorola Mobility TracFone® V170 Cellular...
When I try to make a call, my TrakFone Motorola W175 g displays the notice "Phone restriction -34" and the call fails. I also can no longer receive calls.
Your sim card is bad in the phone. That is the most likely problem. Other than that the phone needs restored to factory settings and try again.
Jun 21, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Cell Phones Logo
120 people viewed this question
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
