Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
I have a sony kp-51ws520 projection tv . when i turn on the red light blinks several times 9 or 10 times,no pitcher no sound,every now and then i turn it on it works, when i turn it off it will not come back on when i try to turn it on.the blinking is back again,no pitcher no sound.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 9 blinks issue in your Sony kp-51ws520 means that the G board is bad and should be replaced however, 10 blinks means that the issue is with the D board and it should be checked and replaced if bad. Please check the no# of blinks to resolve the issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 20, 2010
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Jul 08, 2013 | Televison & Video
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a Sony Kp-51ws520 5 blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Dec 05, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 Stand by flashes 5 times
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Mar 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
264 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
