Question about Kenmore 36665 / 36669 Gas Kitchen Range
I have a kenmore es 330 gas range, and I am having problems lighting it. can not open the top
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
the dr
  • 447 Answers
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
SOURCE: Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Posted on Oct 14, 2007
abhishek33
  • 1239 Answers
SOURCE: Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Posted on Nov 06, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite gas range the oven burner doesnt light right
It appears your gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Testimonial: "thank you"
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Kenmore range will not light, not getting gas flow.
Have you purged the gas line to get gas to the range? What is the model number?
Feb 10, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 17, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Kenmore Elite Gas Range. #790 series. The electronics of the oven seem to be working, but the oven is not getting hot. The stove top (surface) is working. Do you think it is the pilot light? ...
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Jan 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
TRAC OFF, VSC, and check engine lights are on in my 2004 Lexus ES 330
Often caused by a loose gas cap or fouled or failed air fuel O2 sensor. Check your gas cap is fully ratcheted, Drive a day or two. If lights don't clear you will need a code reader attached to the car to diagnose.
Dec 18, 2009 | 2004 Lexus ES 330
Kenmore gas range. The oven will not light. Was recently self cleaned. The top burners work fine.
the problem iss yo uneed a new ignitor (glow bar) just because it glows doesn't mean its ok it has to draw at least 3 amps to open the gas valve
Nov 11, 2008 | Kitchen Ranges
Kenmore gas range
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Oven will not come on.
If you have power to the ignitor but it doesn't come on then the ignitor is bad and will need to be replaced. Good job on checking for power to the ignitor first.
Nov 09, 2007 | Kitchen Ranges
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Dec 22, 2006 | Kenmore 78673 Gas Kitchen Range
Kenmore 36665 / 36669 Gas Kitchen Range Logo
111 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
