Question about Hitachi 65S700 65" Rear Projection HDTV
Whining sound from back of tv sounds like fan must turn volume up to cover noise
  • 58 Answers
This is a 15 k frequency sound
It is usually caused by one or more of the components in the High voltage circut,
with the set on and the back off, take pencil with an eracer.
Then push on each of the coils or transformers to see if it stops or diminishes.
if so coat the part with silicone sealer spreading to at least 2 components nearby. let dry.
This may help.
Thanks guy9
Posted on Jul 08, 2008
Hear whining sound only when heater is on.
Is it the heater fan making the noise? Some can be lubricated, others have to be replaced. I hope this is helpful.
Apr 01, 2014 | 2010 GMC Terrain
When turned off the tv makes a whining sound (not the expected whining noise) and then sounds like a wheel (like on Wheel of Fortune) slowly winding down. Yesterday it didn't come on (sound, no picture) so...
The whining if it sounds like a mosquito type whine! it can be a capacitor, i have same issue, you can usually hear when u are on standby but if your hearing like a "wheel of fortune"! and slowing down would likely indicate it's a fan which is possibly covered in dust and the whining is the fan stopped trying to power forward or it slowly moving and slowing down. If you think it's the fan you should unplug your TV to avoid the fan burning out then have someone who knows what their doing take a look at than fan for you and clean the dust away from it, you may be able to get some access through vents in the side and can try your vacuum cleaner in those vents while TV is unplugged but i'd not go messing inside a TV without wearing some rubber gloves!
Looks like the engineer would need to remove TV casing, check fan to see if it is blocked with dust or not, or if just failing for other reason then either clean or replace. If you don't get it done and the fan fails to cool the TV your risking other vital components overheating and breaking for good so best get it looked at, sounds like the fan to me...
Sep 20, 2013 | Samsung HLR5667W 56" Rear Projection HDTV
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP Model HLP 4663 WX Constant Whining
What you're hearing is the most likely the color wheel if you remove the lamp you can see part of it ...a multicolored plastic disk.It rotates on a high speed motor and make an awful whining noise when it fails.
Rustym62
Apr 30, 2009 | Samsung HLN5065W 50" Rear Projection...
HL-P5O63W : Rear Lamp Cover Error!
That my be the color wheel you are hearing
They will make a huge whining noise
The lamp door also had issues the lamp switch must be in the up position when you put the door back on
Feb 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Hitachi 65S700 65" Rear Projection HDTV Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
