Question about Denon AVR-1601 Receiver
Denon AVR 1601 - Problem with front channels
Hi Guys,
In the last few months my reciever was stored in closet with not too much space for ventilation.
I suddenly noticed that the front speakers are not playing well (mainly low frequencies and sound really bad). the rest of the channels (center and surround) are OK - but in any case the reciever got to high temperatures...
I moved the reciever to a better location (with enough space for ventilation) but the problem still persists.
Was something damaged by the heat? what can I do in order to repair the problem?
Thanks!
Yoni
Hi yoni there is circutshort problem in your receiver and you have to get it fixed by someone works for stereoshop because this is not a fta receiver which has files problem. your receiver has burnt a circut fuse type of wire preventing the curret to the speakers.
Posted on May 03, 2008
Service manual
http://www.smpcshop.com/Denon-AVR-1601-AVR-681-Service-Manual.html
Sep 11, 2013 | Denon AVR-1601 Receiver
I have done some research about my denon arv-1601 reciever, narrowed it down to a ressistor problem, it turns on for 4 seconds and turns off and goes into standby mode. Any Suggestions?
Usually it is bad power supply problem or bad channel problem. Look for any burned parts, it helps you locate the problem. Burnt resistors in one channel- you need to replace output transistors (better to replace all transistors in that channel) and bunch other surrounding parts. If you do not see any burned parts, check all voltages coming from power supply +15 -15 +5 etc then check dc at every channel output (not at speaker terminals but at control pins on the amp/main pcb), should be +-10mV
Sep 05, 2011 | Denon AVR-1601 Receiver
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Dennon AVR-1601, Installation, Connections & Operating
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Jan 06, 2009 | Denon AVR-1601 Receiver
Manul denon avr-1601 en castellano
Espagnol as well ...I think
Dec 12, 2008 | Denon AVR-1601 Receiver
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
Denon AVR-1601 5.1 Channels Reciever
The receiver is going into protect mode. There is an internal fault of some sort. Usually a bad component or components in the power amp section. If your looking for "transmitters" instead of "transistors", I suggest you seek professional service.
Sep 18, 2007 | Denon AVR-1601 Receiver
Hooking up dvd, tape, karoke machine to denon reciever
What happens when you select options from the front of the reciever?....accordianman
Sep 07, 2007 | Denon AVR-2106 Receiver
Avr receiver
More than likely audio o/p problem.could be speaker problem,dissconnect speakers and try to power on if still no go it is job for technician.If it works one of your speakers has a short on it,good luck
May 14, 2007 | Denon AVR-1601 Receiver
Buttons not working
Have you checked whether the front panel of your reciever hinges down or up if it does there may be a cut off button under there which when operated will let the front panel buttons work again
Dec 21, 2017 | Denon AVR-1601 Receiver
Denon AVR-1601 Receiver Logo
83 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
