Question about Marantz Audio Players & Recorders
I own a Marantz cd 63 MK II player. The problem with the set is that the CD tray is not coming out as the gears are broken. Please tell me where I can get the tray mechanism or the gears and the lens too. I want to get the set fixed as I like it too much.
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
  • 3422 Answers
SOURCE: Marantz CD-5000 CD player
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
Posted on Feb 22, 2008
ginko
  • 19396 Answers
SOURCE: Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Posted on Jun 01, 2008
SOURCE: Marantz cd 63 player has
Cleaned laser lens carefully with a cotton bud dipped in isopropyl alcohol. Waited for it to dry before trying. Success!!
Posted on Aug 24, 2008
SOURCE: problem with Marantz DV 7001 DVD player
I have long resolved the problem. I returned the damn thing.
BTW I have tried everything including changing resolutions. Nothing worked. Had to listen to a whole lot of nonsense from the worst (Marantz') customer' service in the world! Not my problem anymore. Good luck to those who have these models. To those only thinking of getting this player, my suggestion - do not! Better get top of the line Pioneer Elite.
Posted on Dec 09, 2008
Loading judder, is there a tray mechanisim out there ?
You may just need a belt- it depends on what you can see what is happening. MCM Electronics has small square belts that could resolve the issue. There is a Marantz/Denon service parts place but you need to have a service manual to be able to order the part you want. It is probably a simple belt replacement.
Dec 10, 2012 | Marantz CD-17 CD Player
My Marantz 63 Cd Player makes a loud sound as it opens and/or closes.
It may require lubrication, or the gears are showing signs of ware. If it is a lubrication issue you will need to dis-assemble the unit to track the source and address the problem. It is possible part of the mechanism has come loose.
Mar 05, 2012 | Audio Players & Recorders
Hi, My young daughter held the tray on my new cd5001 player as it was opening. The tray now opens and closes continually while the unit is turned on. It will not play discs and the words open & close...
while your daughter was "holding" the tray did you hear any "popping" type noise?
This is a typical sympton when the gears have skipped a few teeth!
Your best bet(IF your a "handy" person) would be to take the unit apart to get to the CD drive, and CAREFULLY push/pull on the tray to manually "open/close" it, and watch the tray in correlation to the "eye" mechanism, to see if it is aligning with the "hole" in the tray correctly!
Jan 22, 2011 | Marantz CD5001 CD Player
Marantz cd67se mk 2 Door does not open when button pressed
i had the same problem on a marantz cd-63 which is virtually identical
and it turned out to be a faulty button on the control PCB.
i replaced it with one out of a scrap PCB and all worked as it should.
hope this helps.
Dec 13, 2009 | Marantz CD-67 SE CD Player
Can't eject cd so how can i get it out of my marantz cd-6000 cd player
take the lid off and manually push out the tray.
alot of marantz and philips allow for this rather than fiddle with hard to reach cogs like on other players.
hope this helps.
Nov 30, 2009 | Marantz CD-6000 CD Player
CAN YOU PLEASE TELL ME HOW TO CONNECT A SET OF SPEAKERS TO THE CD PLAYER PLEASE? WOULD I HAVE TO USE AN AMPLIFIER THEN TO SPEAKERS AND HOW WOULD I COME FROM THE MARANTZ CD PLAYER ? THANKS -GRAHAM
You will have to use an amplifier to power the speakers from the cd player, the output on the CD player isn't enough. You will need to hook the CD player to the amplifier using the red and white wires, on the CD hook them to the OUT and on the amp hook them to the CD or Aux or Tape in. Then select that input on the amp and enjoy the music.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 05, 2009 | Marantz CDR631 CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Faulty eject tray
hello you have a dirty switch on erratic use clean or change it
this switch is usually under the main drawer saludos
Jan 08, 2009 | Audio Players & Recorders
Marantz cd 67 mark 2 (Original SE)
you might be able to get it fixed future shop can take alook at it and tell you if it can be fixed
Feb 16, 2008 | Marantz CD-67 SE CD Player
43 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
