Hi please check the tank breather it maybe allowing to build up pressure and unsseating the needle valve
try another breather or tank cap if it uses cap with breather
check that the main check valve / nozzle is working correctly
you mentioned carb has been re-kited
did you fit the pump diaphram on carb then the pump gasket ?
also the metering diaphram has the gasket 1st then diaphram then the cover ( make sure vent hole is clear on cover )
but sounds like a faulty breather
cheers
