Question about Sony Network Walkman NW-A3000 MP3 Player
Codigo de error 00004e2e no puedo entrar al programa sonic stage y sale que la configucion del sistema ha sido cambiada
thassall4295
  • 91 Answers
SOURCE: software
You maybe able to use Windows Media Player 10 or 11, if you want to try well connect your mp3 player to the computer now wait a few seconds then go to Windows Media Player ( if your using windows media player 10 i recommend you to update to media player 11 for better results but if not when your on Windows Meda Player look for a link called "Sync" when you've found it click on that.
Now your on "Sync" if should have found your mp3 player now just drag and drop music you wish to have on your mp3 player on the side panel where it's got a little image of an mp3 player.
Once you've added the music, safely remove the mp3 player like you normally would then see if the music has successfully tranfered.
Here is the new Windows Media Player 11 if you haven't got it already.
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Good luck. Hope my solution was helpful.
Posted on Oct 26, 2007
WeListen2You
  • 538 Answers
SOURCE: Notebook Sony Vaio VGN-FJ270
La única manera de hacer esto es hacer una recuperación de sistema en el disco, si se asume que esto fue fijada realmente y funcionamiento. ¿si no, usted tiene un respaldo para estos datos?
Posted on Oct 23, 2008
  • 566 Answers
SOURCE: Cómo puedo que mi grabadora sony
Descarga esto software Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit Windows versiones no son por el suportadas.
Posted on Jul 28, 2009
SOURCE: nO HAY DATOS
el formato de los datos era compatible con tu reproductor
Posted on Aug 25, 2009
davidmamian
  • 543 Answers
SOURCE: No funcionan los botones del sensor tactila mi lap
reinstall drivers for your new system.
Posted on May 29, 2011
Al encender mi computadora me pide de inmediato password y no me deja ingresar al sistema. Como puedo desbloquear la clave de la BIOS para poder entrar a trabajar en windows?
Fue alguna password que inseriste antes?
Algo que estuviste haciendo en la BIOS?
Puedes intentar apagar la memoria de la BIOS, retirando la bateria de memoria que se encuentra en el interior del ordenador.
Para eso tendras de desarmar el ordenador, retirar la bateria interna por 10 segundos, e volver a poner.
Nov 11, 2013 | Compaq Armada 1573D Notebook
Que significa SRS en el panel de mi mitsubishi mirage 1995
Hola:
EL codigo SRS se refiere al sistema de seguridad del vehiculo (Air Bag System), y aparece cuando se presenta algun codigo de falla en el mismo.
La presencia de un codigo de este tipo no sera eliminada con solo desconectar la bateria durante algunos minutos; necesariamente tendra que llevar el vehiculo a su representante o algun taller que cuente con lector de codigos (scanner) para determinar exactamente que codigo de falla se ha presentado, Solamente con este codigo podriamos ofrecerle mayores detalles.
Suerte.
Jul 10, 2012 | 1995 Mitsubishi Mirage
Como eliminar el security error del verifone vx670
Hola como te va sabes el problema que tienes con tu maquina no lo puedes arreglar tu necesitas mandar la unidad a un centro de reparacion por que necesitas el programa para remover el error que tiene la maquina solamente con el software de ellos siento no poder ayudarte pero si tienes alguna duda llamame al 775- 358-2922 : - )
Jun 12, 2012 | VeriFone Vx 670 Payment Terminal
Compre una imac m6498 pero cuando la prendes aparese una carpetita con una carita seguida de otra con un signo de interrogacion que puedo aser para que funcione
Normalmente el simbolo que mensionas sale caundo el sistema no purde encontrar el disco duro. Pera verificar si es el disco duro que esta fallando o no, completamente apages la computadora. Oprime el boton de poder e imediatamente oprime el boton "Option" y mantenga la tecla selecionada. Esto le senala al sistema que quieres ver todas las seleciones para butiar. El sistema debe mostrar un imagen del disco duro si no esta fallado. Si lo ensena, puedes selecionar el disco duro con el mouse o usando las teclas de direciony oprimes el buton "Return" or "Enter".
Si ningun imagen aparece o mas importante, si no muestra el imagen del disco duro, eso indica que el disco duro ha fallado y necesesitara re-emplaso. El sistem de OS X necesitara ser re-instalado con todos sus aplicaciones tambien.
Jul 18, 2011 | Apple iMac G4 Desktop
Tengo una explorer 98,en la manana,que la prendo,se sube y se bajan las revoluciones del motor,pero no echa humo,hasta al rato se queda sereno el motor.ya me prendio el check engine
Si se encendio el "check engine" sugiero escanear el computador para poder determinar que codigo de falla ha sido advertido con esta luz; podria tratarse de algun problema con los sensores de emisiones, pero la lectura exacta del codigo nos dara mayores pistas para poder diagnosticar y resolver el problema.
Mantengase en contacto.
Jun 03, 2011 | 1998 Ford Explorer
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
Apr 04, 2011 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Kodak ESP 5 Printer
COMO BAJO EL PROGRAMA DEL DRIVE DE VIDEO Y SONIDO A MI PC
Si tu instalación de Windows es reciente, es muy común que tu sistema de audio no haya sido detectado y habilitado inicialmente. Pero, si usas Actualizar Windows, la segunda o tercera ocasión verás que Windows detectó la falta del controlador de audio en el sistema,
y lo instalará automáticamente.
Si este no es el caso, entonces necesitas usar el CD que vino con el tablero, y si buscas en su contenido encontrarás un directorio llamado "Drivers" o algo parecido, o bajo el nombre del fabricante del aparato de audio.
Si logras encontrarlo, entonces ve al Panel de Control y corre el Device Manager (no sé cómo lo llama en español), que es el que despliega la información acerca de los componentes internos y externos de tu PC.
Muy probablemente encontrarás al menos uno o dos que tendrán un ícono amarillo, o rojo, indicando que el aparato en cuestión no está configurado y por supuesto, no funciona.
Si este es el caso con tu tarjeta de audio, entonces haz un click con el botón derecho del ratón sobre el aparato y selecciona "Desinstalar" (o como se diga en español). Cierra todos los programas y recicla tu PC normalmente, usando "Inicio->Reiniciar el sistema".
Cuando Windows arranca otra vez, espera unos minutos. Verás mensajes de que Windows ha detectado nuevos componentes, y que está instalando sus controladores. Un par de minutos después, todo estará de vuelta a la normalidad.
Si en vez de esto el mensaje dice que no se pudo instalar, o no se encontró, entonces busca, dentro del Panel de Control el ícono para añadir componentes. Aparecerá una ventana donde los nuevos componentes se detectarán automáticamente, pero nuevamente aparecerá el mismo mensaje de que no se encontró el controlador. Pero, te da la opción de buscar en un lugar específico de tu sistema por el controlador.
Aquí entonces busca la letra de tu aparato de CD/DVD, que contiene el disco que vino con el tablero, y seleccionas el directorio anterior. Luego, presiona OK/Continúe tantas veces como sea necesario.
En el último de los casos, dirígete a la página del fabricante de tu tablero, y anda a la página de apoyo al cliente, en la página de Descargas busca el controlador, basado en el modelo del tablero en cuestión.
¡Buena suerte!
Jul 17, 2009 | Asrock 775VM8 Motherboard
Error en sistema 0013 en BenQ DC610
CBCX, efectivamente el error se debe a que el lente se trabo y no pasa las pruebas movimiento iniciales que hace el equipo al encender. Por esta razón aparece el error de 0013. Mi experiencia a sido que el engrane que provee de este movimiento se sale de su posición original provocando que se trabe. Yo tengo una cámara del mismo modelo. El problema se resuelve abriendo la cámara y ajustando el engranaje (Es un pequeño engranaje rojo que esta en la parte superior del lente). Adicionalmente se debe fijar el soporte del engranaje, yo coloque un poco de cinta adhesiva en el soporte del engranaje para que no se mueva nuevamente. Esto en la mayoría de los casos resuelve el problema de manera permanente. Adicionalmente es recomendable actualizar la última versión de firmware del equipo.
Como referencia, he descubierto que si estas en el campo tomando fotografías y te ocurre el problema, si le das un golpe firme con el pulgar, en la parte delantera de la cámara justo entre el flash y el emisor para el ajuste del foco el problema también se solventa de forma temporal ya que el engrane entra nuevamente en posición. Puedes hacerlo también dentro del estuche de la cámara con la palma de la mano. A pesar que esto nunca falla, el equipo queda funcionando nuevamente, esta reparación es de carácter temporal y adicionalmente, es obvio que no es sano recomiendan esta práctica, pero puede salvarte en caso de que estés de viaje tomando fotografías y no tengas un servicio especializado.
Feb 03, 2009 | Nikon Coolpix 3200 Digital Camera
Sony Network Walkman NW-A3000 MP3 Player Logo
283 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
