Question about Nikon Coolpix S210 Digital Camera
There is a little flashing red clock on my camara. What does that mean?
Reset the time and date
Posted on Dec 09, 2010
2 Suggested Answers
akangpepen
  • 133 Answers
SOURCE: okay theres a little red
hi there, that indicator means that you haven`t set the time and date on the camera
you can easily troubleshot this by choosing MENU then set the date-time
hope this advice will help
Posted on Jan 06, 2011
1998 Ford Towncare has an airbag code 32 - 3 flashes than 2 flashes, what does this mean
this code means driver side air bag circuit high resistance or open. in a ford, this is usually a bad clock spring. the clock spring is behind the steering wheel. these can be a little bit tricky to replace. the steering wheel will have to be removed. total time would pay 1.3 hours at a shop.
Nov 04, 2012 | 1995 Lincoln Town Car
Red clock continues to flash...how do I turn it off
You declined to specify the make and model of your camera, but on many cameras a flashing red clock means that you need to set the date and time. For the exact procedure, consult your manual.
If you need further assistance, feel free to reply to this post, but be sure to specify the make and model of your camera.
Mar 24, 2012 | Cameras
What is the meaning of symbols on Nikon Coolpix L120
All of the symbols are described and explained in the manual. If you need a copy of the manual, you may download one here.
If you're referring to a red flashing clock, that indicates that you need to set the date and time.
Dec 26, 2011 | Nikon Cameras
Okay theres a little red flashing clock on my camera what does that mean?
Jan 06, 2011 | Nikon COOLPIX L4 Digital Camera
What do the warning lights on the 2004 VW Passat dashboard mean as they are a few flashing and I don't know what they mean?
Depending on which light is flashing will determine whats wrong, normally thee are three lights that flash one is yellow check engine light, when it flashes it means a misfire and catastrophic catalytic converter failure. Red oil light means your low on oil and if it does not have a gage you may have damaged the engine and then there is several others like air bag warning light this would be caused by a defective clock spring, or a malfunction in the computer system. Your best bet is call your local dealer and describe to them your problem and tell them what lights are flashing they can determine weather you should drive it or have it towed in for repairs. Remember FLASHING RED OR Yellow light means imminent failure of expensive engine parts.
Jan 15, 2010 | 2004 Volkswagen Passat
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
A red box with clock flashing?
It means you need to set the correct date and time in the setup menu. It will keep taking pictures, but it's telling you that you have not set up the correct time & date in the camera.
Dec 13, 2008 | Nikon Coolpix L11 Digital Camera
What does MF mean ?
MF means Manual Focus, to change it to auto mode go to focusing menu and change it to continues or single mode
Nov 04, 2008 | Fuji FinePix S5000 Digital Camera
Flash issues
It means that the battery is charging the flash! Wait a while and it should stop. Then take your photo.
Do make sure your battery is fully charged.
Apr 05, 2008 | Olympus FE-220 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
485 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
