Question about Memorex MMP8565 MP3 Player
My memorex MMP8565 MP3 player will not boot. I have tried reset and charging but it will not come on.
  • 6,784 Answers
HI. This unit has internal memory(1gb) that can become unstable, thus, causing start up issues. With that said; This will most likely be a dead cell(battery). I would replace the battery with a new one if it is over 1 years old. This lithium cell may be defective. Once you have purchased a new battery, be sure to charge it fully before using the player. It takes three whole hours to set a newly purchased lithium cell. Once that is done, power up the player and update your firmware. Use the steps below to update properly:
1. Download the updated firmware at www.memorexelectronics.com.
2. Unzip the file, then double click setup.exe in the Desktop folder to install the software to your computer.
3. Connect the player to the computer using the supplied USB cable and the installation screen will appear. (If the installation screen does not appear, unplug the USB cable and turn off the unit). Connect to the computer again and press and hold the Power On/Off/Stop button until the installation screen appears.
4. Follow the on-screen instructions to install the driver.
5. When finished, click START and locate the newly installed software “Deco” andselect “Firmware Download”.
Now, after the update, you will need to reformat the player. Use the steps below to achieve this:
1. Use the USB cable to connect the player and the computer.
2. Double click on My Computer, then right click "MPT Player", "MMP8565"or "Removable Disk" and left click on"Format".
3a. For "MPT Player" or "MMP8565", at the "Format" window, click OK to confirm and the player will start to format . When
finished, click "OK" to close the Format window.
3b. For "Removable Disk", at the "Format" window, select "FAT 32" from the file system pull-down menu, then click "Start" to format the unit
  • NOTE: Make sure you have selected "FAT 32" at the file system pull down menu; otherwise, after formatting, the player will not work properly.Then, click OK to confirm and the player will start to format. When finished, click "Close" to close the Format window.
  • NOTE; If for some reason you cannot update your firmware, you will need to reformat the player first, then, update the firmware after the reformatting process.
Posted on Aug 20, 2010
Testimonial: "It's probably easier to buy a new one.... "
  • Airegla Aug 23, 2010
    apparently the mp3 doesn't even turn on...
  • Michael Masters
    Michael Masters Aug 23, 2010
    HI again; if the unit continues to no power up even after replacing the battery, that will indicate that the internal hardware is damaged. A new unit will be more cost affective. Replacing the micro hardware will be more expensive than a new unit.
I have a Memorex MMP8565 that i had not used for a while and now I keep getting a boot error. How can i correct this? Thank you
This problem can be easily fixed by running an update called firmware provided by Memorex. If you have the color display, by following the link below you will find the file to download which contains the executable application and instructions to run it.
http://www.memorex.com/en-us/Portable-Electronics/MP3-Players/Digital-Audio-Player-with-1GB-Memory--Color-Display/support/
Jul 10, 2010 | Memorex MMP8565 MP3 Player
When I turn my player on it says boot error, shutting down I have songs on it and have been using it for five months. This is a new problem. Memorex mmp8567
Memorex=3M. Like the video tapes, it's guaranteed for life. There's probably nothing you can do yourself if it uses MTP as opposed to UMS, otherwise you could just format it on your PC and start over.
Oct 30, 2009 | Memorex MMP8565 MP3 Player
Memorex MMP8565 Digital player cannot delete songs
go to settings the format and click okay.
(Note: It'll delete all your songs.)
Nov 19, 2008 | Memorex MMP8565 MP3 Player
Memorex MMP8565 FROZEN!!!
Is it possibly rebooting in locked mode?
Sep 01, 2008 | Memorex MMP8565 MP3 Player
MP3 won't turn on
you my need to reset the player i have the same one there should be a reset hole on top of the player get some long and small object and push it. After that you should get the firmware upgrade to upgrade its reponce. but befroe you upgrade earse all the songs first by going to the settings go all the way to the bottom and press format it will earse every thing and rebout the player after you reset it.
Aug 07, 2008 | Memorex MMP8565 MP3 Player
Charging the battery by the computer
Reformat the player - the instructions are in your user's manual, which can also be obtained off the internet at: http://www.memorexelectronics.com/html/product_detail.php?PID=650#
If that fails, get the firmware upgrade from the above-mentioned website
Jun 04, 2008 | Memorex MMP8565 MP3 Player
Boot Error, Shutting Down
Go download the firmware from the memorex site. Hole the power and left buttons as you plug it into your computer. It'll be detected as a recoveryclass device, the firmware program should be able to reflash the device and fix it. If not, hold the power and left the entire time that the firmware detector scans, then let it flash the device (including formatting the data area) and you should be good to go.
Mar 01, 2008 | Memorex MMP8565 MP3 Player
HELP!!!!!!!!!
Replace it -there's nothing more that can be done
Feb 20, 2008 | Memorex MMP8565 MP3 Player
The memorex mmp8565 digital audio player
When you take it off charge you must take a pin and stick it in the reset button, it will turn on
Nov 30, 2007 | Memorex MMP8565 MP3 Player
Memorex MMP8565 MP3 Player Logo
641 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
