Question about Microsoft Windows XP Professional for PC
Is there a free microsoft registry cleaner for windows XP pro that will go through the process and complete the function without asking me at the end to purchase the software
    President:
  • 2,571 Answers
YES.
CCleaner, this has a registry cleaner built in.
Its free and can clean your temp files, your registry, delete unwanted restore points, and clean up your start up folder, so you can stop unwanted programs starting when you boot up
http://www.filehippo.com/download_ccleaner
Posted on Aug 20, 2010
    President:
  • 2,291 Answers
Reginout register cleaner intel partner is a very gud registry cleaner , it has many features, it will help u alot
Posted on Aug 24, 2010
    Sergeant:
  • 201 Answers
HI TYPE IN YOUR SEARCH ENGINE CNET/TYPE IN THERE SEARCH /ADVANCED SYSTEM-CARE.DOWNLOAD/ INSTALL THIS PROGRAM IS FREE.IT TAKES CARE OF REGISTRY/SPY-WARE/ REMOVAL/ PRIVACY SWEEP/ETC.HOPE THIS HELPS.
Why does System Mechanic Pro 14 freeze before it totally completes optimizing disc drive. May be 30% or 70%. Have had running 6 hrs. and still not complete and has not advanced for 2 hours. Sounds as...
I would cancel it, then run CCleaner, then run SMP14 again (if you want to)
I have found CCleaner to be the best Registry and Temporary File cleaner. It has a free version, which is what I use on each Windows Account, every few months.
Configuring:
On the Cleaner/Windows tab, I uncheck "Thumbnail Cache".
On the Cleaner/Applications Tab, I uncheck SUPERAntiSpyware, MalwareBytes, Windows Defender, MS Management Console, and MS Search (if they are present).
Running:
Start CCleaner.
Cleaner - Analyze, then Run Cleaner (click OK)
Registry - Scan for Issues, then Fix selected issues (Yes, Save, Fix All Selected Issues, OK, Close)(Repeat the Registry process until no more issues are found, or the same ones are found each time)
Click the red X to close Ccleaner.
Good luck.
G
Aug 05, 2014 | Iolo Technologies System Mechanic...
Gentlemen: I have downloaded MS 2007 for free from Brothersoft website. After installation, i can't use all the programs, such as excel and word. Every time i attempt to encode, this statement flashes...
Microsoft Products including Office 2007 are licensed software and cannot be used without the product key. You can only download the trial version.
Instead you can use OpenOffice, which is an absolutely FREE and open source office and productivity suite. Refer here to my earlier solution regarding Office Suite. OR. If you wish to use Office 2003, you have to uninstall Office 2007.
To uninstall you can use any uninstaller or uninstall the program using "Add Remove Programs" from the control pannel. As stated by you, if you are having problems uninstalling MS Office 2007, as a work around, manually delete the MS Office 2007 folder from the 'C:\Program Files' and Start Menu. After that you can use the following software to fix the registry entries left by Office 2007 and the remaining files etc.
-You can use Registry fixing software/utility. I have come across a Registry Tool, which is effective to fix common Registry issues. Its Free, small size, easy to use and completely safe. Click here to download CCleaner. Install CCleaner, Click 'ISSUES' and 'SCAN FOR ISSUES' and then click 'FIX SELECTED ISSUES'. Also, Run cleaner from the main interface of CCleaner.
Make a backup of the registry and proceed. You may proceed without registry back, if you like.
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Computers & Internet
Two conflicting microsoft offices,...2007 enterprise and pro plus so pro plus has the error and when i try to delete pro plus it wont delete says i need a disk but i lost it
try the restoration method if it's hard to delete that,this works if you're windows xp pro ...follow this steps; Click windows start>pointing all programs>click accessories>system tools>then system restore..
On system restore window tick on "restore my computer to an earlier time"
click next then select date and time to when your computer works good,or before that program was installed before the error occurs..
click next then next...wait untill the process complete...click ok after finish..
hope this help, goodluck
Feb 21, 2011 | Microsoft Office Professional 2007 Full...
I don't want Palladium on my computer and I can't delete it
Manual Removal procedure for Palladium Pro The first step you must take in order to remove Palladium Pro is to stop one of the following processes below. Only one of them will be running.
  • Palladium.exe
  • PalladiumPro.exe
  • Palladiumantivirus.exe
  • Z.exe
To Stop this process you can browse to the file location shown below and re-name the file first and then restart your computer. Then browse to that file location again and delete the file.
The next step in Palladium Pro removal is to delete the following file:
Windows XP :
  • C:\Program Files\Palladium Pro\PalladiumPro.exe
  • C:\Documents and Settings\USER NAME\Application Data\Palladium.exe
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files\Startup\Palladium Pro.lnk
Windows Vista / Windows 7 :
  • C:\Users\YOUR USER NAME\AppData\Palladium.exe
  • C:\Program Files (x86)\Palladium Pro\PalladiumPro.exe
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files (x86)\Startup\Palladium Pro.lnk
  • C:\%AppData%\Z.exe
Once you have successfully deleted these traces, Palladium Pro should no longer be running in your machine and now you should run a complete virus scan for the system using Spyware Doctor with Antivirus. This will let you know whether you have been able to remove all the traces of Palladium Pro successfully and also whether there is any other threat still available in the system.
If you need advanced help or an expert we recommend www.onlinecomputerrepair.org
Palladium Pro Registry Removal Procedures Now that your system is free from the Palladium Pro file traces that have been mentioned above, it is time to get rid of the infected registry items.
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium"
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium Pro"
  • HKEY_CURRENT_USER\Software\Palladium Pro
It is important that you run a complete virus scan for your computer when you are done with the removal procedure to ensure maximum protection for the system. For that, we suggest you to run the scan with Spyware Doctor with Antivirus.
Palladium Pro Directories: XP
  • UPDATED: We have a report of it being at C:\Windows\Palladium Pro for some users.
Windows 7 / Windows Vista
  • C:\Program Files (x86) \Palladium Pro
Or mail me googolplexcorporation@gmail.com we will remove it through remote desktop support
Jan 27, 2011 | Computers & Internet
My computer runs really slow and sometimes it tells me it cant load because i dont have enough memory and i was told by a friend that i have to many processes running . how do i know which processes to...
There is a program called ccleaner. You can download at hippo.com for free, even the current version. This program will clean everything you need it to clean.
Dec 28, 2009 | Microsoft Windows XP Home Edition
On main desktop screen the message is displayed "ask for genuine software. you may be a victim of counterfeiting". how can remove that message??
this message popping up because your computer is running a pirated version of the software,try this:
  1. Start/run/type "regedit"/hkey_local_machine/software/Microsoft/WindowsNT/Currentversion/Winlogon/notify
  2. Now the folder notify...delete it...nd then restart ur pc...nd wala problem solved it wont bug u no more...
  3. Good luckl!
Dec 18, 2009 | Microsoft Windows XP Professional for PC
My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start-> Run-> Regedit). In the registry editor, navigate to the entries mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not comfortable about deleting registry entries, you can use a free registry cleaner. If you are using a 64 bit machine, then these are the entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be completed normally. Alternatively you can also use the AVG cleaner or Kaspersky removal tool for AVG8.
Jul 21, 2009 | Microsoft Windows XP Home Edition
Windows xp sp2 reboot
You can start by downloading GUIDED HELP .
This application is provided for free in the Microsoft Knowledge Base.
The registry is a volatile environment to enter without prior experience
or the presence of a full backup.
Startup and shutdown issues are addressed by a variety of registry keys
and you can destroy your system with good intentions. This is an area
best addressed by Microsoft as I have seen mixed results with so-called
registry cleaners. Also get a full understanding of how to use ASR
in Windows XP.
Hope this gets you started.....................Nate P.
Jan 17, 2009 | Microsoft Windows XP Professional
Microsoft Windows XP Professional for PC Logo
303 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
