Question about Fuji FinePix A345 Digital Camera
When i turn my cam on a black screen comes up saying zoom error how do i fix this??
  • 3,866 Answers
Genrallt a NonExpert repair on this camera would rendar it useless, The zoom motor is most likely your issue, But if you dig in the lens housing for this motor your going to expose the camera.
I would say:
1. Take it for a estimate
2. If it cost more then $40 its not worth the repair as there going to hit you up for parts.
Basically if someone is asking "how do i fix my camera" they are basically end users and end users do not fix there own camera because of the very delicate parts inside of a camera and what not.
Thanks for hearing my advice. please do not forget to rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 20, 2010
When I turn camera on it says zoom error! How do I fix the problem?
Try playing with the zoom in and zoom out buttons it usually comes from a a jammed zoom lens.
you also may want to try helping it out.
Mar 02, 2011 | Fuji FinePix A900 Digital Camera
The zoom lens gets stucked and cannot come out when I turn on cam
Lens probably does not extend or retract because of debris or a misaligned gear box. Thelens can in about 50% of the cases be repaired without having to replace it. Try toreturn to manufacturer first. If you're out of warranty, there arethird party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 09, 2010 | Nikon Coolpix S210 Digital Camera
Blurry images (after a lens error)
There is a mechanical displacement in your camera. Definitely, it is not a software problem. Actually Digi Cams are very delicate, especially small ones.... So get it serviced from a authorised service station. They will fix the problem....
Pleas rate the answer iof you find it useful.
Apr 27, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
I fixed the first problem..!
I fixed the "zoom error" problem..but to be honest I'm not exactly sure how..i found some "jewelers tools" and following instructions found on this sight,ever so carefully,started unscrewing screws.First I removed the lens shroud,made sure it was clean...nothing..still had zoom error so then proceeded to remove the back of the camera..looked around and kinda "shook" it out.There was one little screw left that was preventing me from getting to the gear box but it wouldnt budge and i was afraid of stripping the screw so I said heck with it and reassembled it..figured what the heck and turned it on OMG! imagine my thrill when the lens zoomed in and out just like it is supposed to! But then i inserted memory card,turned it on and got the "zoom error"message again followed by "no card". Now what?
Apr 13, 2009 | Fuji FinePix S304 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
Fuji FinePix A345 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
