Question about Boating
I have a 1997 Sea ray boat, I changed the distributor cap, an I mixed the wires up...The engine is a mercruiser 3.0L/LX (4 Cyl).the firing order is from front to back 1-3-4-2...I need the firing order for the cap please.
    Problem Solver:
  • 17 Answers
Unfortunately, it varies, but if your proper order is in fact 1-3-4-2, the #1 wire goes to the front left position (~ 1030 clock position viewing the engine from the top looking forward) on the distributor, and thence clockwise from there. Might want to check this out...
http://www.baylinerownersclub.org/forum/showthread.php?t=31473
Posted on Sep 27, 2010
NEED FIRING ORDER FOR 1997 LEXIUS 450
There should be an EPA sticker somewhere in the engine compartment, which will show vacuum line routing, firing order, and spark plug gap. If that sticker is missing, you may need to contact a Lexus dealership, give them your VIN number, and have them provide the information for you.
May 06, 2015 | 1997 Lexus LX 450
Wiring
if you mean the plug wires do the following. remove number one spark plug,turn engine over till you feel compression coming out of cylinder, find tdc mark on timing cover, turn motor over till mark on crankshaft pully lines up with timing cover mark, remove distributor cap, rotor now points to number one plug wire, check rotor rotation, firing order 4 cylinder motor 1324 6 cyl 153624.
Aug 16, 2014 | Cars & Trucks
Daewoo tacuma Just changed my spark plugs and HT leads now enging runs rough and stalls on idle
CHECK YOU FIRING ORDER, YOU MIXED THE IGNITION WIRES, IF IT IS A 4 CYL, FIRST CYLINDER #1 IS NEAR THE BELTS, CHECK COIL WIRES FOR NUMBERS, OR DISTRIBUTOR CAP FOR CYLINDER NUMBER OR COIL PACK FOR CYL #, AND FOLLOW THE WIRES TO THE SPARK PLUGS. MAKE SURE THEY ARE RIGHT, NEXT TIME DO ONE PLUG AND ONE WIRE AT THE TIME.
May 22, 2014 | Cars & Trucks
I changed the spark plugs and wires on my chevy s10 2wd pick up, which is a 4 cylinder and now it will not turn over. I might have the wires mixed up on the distributer cap. Can someone show me a picture...
GET A PIECE PAPER DRAW A LARGE CIRCLE TOP UPPER HALF CIRCLE LEFT TO RIGHT WRITE NUMBERS 1 AND 3 BOTTOM HALF CIRCLE LEFT TO RIGHT RIGHT NUMBERS 2 AND 4 THAT YOUR DISTRIBUTOR SPARK PLUGS WIRES LOCATION.STANDING ON SIDE OF ENGINE WHERE DISTRIBUTOR IS LOOKING DOWN AT DISTRIBUTOR 1 AND 3 FIRST TWO SPARK PLUGS TERMINALS NEXT TO ENGINE. AND 2 AND 4 SPARK PLUGS TERMINAL ON CAP FACING YOU. THIS IS CYLINDERS LOCATIONS STANDING IN FRONT OF ENGINE.RUN WIRES FROM DISTRIBUTOR CAP TO PLUGS TO THE ENGINE SPARK PLUGS.
Oct 17, 2010 | Chevrolet S 10 Cars & Trucks
Need a diagram for the firing order for a 1998 Dodge durango 5.2 engine. I think I mixed the wires up. Help!
Firing Orders NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
If a distributor is not keyed for installation with only one orientation, it could have been removed and installed improperly and then rewired. The new wiring arrangement would maintain the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes of the current plug wire locations and orientation of the distributor cap.
1-6-5-4-3-2
5.2L Engine 1-8-4-3-6-5-7-2
5.9L Engine Firing order: 1-8-4-3-6-5-7-2
Oct 12, 2010 | 1998 Dodge Durango
I have a 1997 Toyota Camry 4-Cyl. I need the plug wire firing order on the engine and the cap. I think I may have crossed my new plug wires.
Here you go free of charge curtorsey About.com I do not have a photo of the distributor cap. Just turn the engine over until the #1 piston is at TDC on the compression stroke and the rotor will be pointing at the #1 piston. Connect that to the #1 plug and then connect the next on to the # 3 plug going counterclockwise, then 4 and finally 2. 53f57a7.png
Oct 11, 2010 | 1997 Toyota Camry
Need firing order diagram for 91 s10 blazer
991 Chevy S10 firing order
The firing order for a Chevy s10 depends on which engine you have.
1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise.
2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise.
2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise.
4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
Jan 09, 2010 | 1991 Chevrolet S-10
Changed plugs and plug wires and now it wont start? i checked for spark off the distributer all 6 were good?
if your engine run before you changed anything,and you are talking about a 3.0 engine,
you have to be careful changing wires on this engine,
you need toonly change one wire at a time,the distributor cap on this engine is just stupid.
if you look under the cap you'll see that a wire on the one side of the cap actually has a contact that leads to the other side of the cap.
cly 5 cyl 6
cyl 3 cyl 4
cyl 1 cyl 2
front of engine
if your looking at distributor cap from front of engine,
two screws hold down cap.
look at the screw closest to the front,from that screw second hole to the left is #1.
firing order is 123456
#2 wire will be at that front screw on cap,keep installing wires counter clockwise.
Dec 07, 2009 | 1996 Chrysler LHS
Firing order diagram for 1998 Jeep Cherokee Sport
1998 Jeep Cherokee 4WD 4.0L MFI 6cyl
To avoid confusion, tag and remove the spark plug wires one at a time, for replacement.
If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes to reflect how your engine is wired.
Fig. 1: The firing order can usually be found cast onto the intake manifold
Fig.: 1989-98 2.5L engine Engine firing order: 1-3-4-2 Distributor rotation: Clockwise
Fig.: 2.8L engine Engine firing order: 1-2-3-4-5-6 Distributor rotation: Clockwise
Fig.: 4.0L engine Engine firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
Fig.: 5.2L and 5.9L engines Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Also, here can review the Jeep XJ Service Manual.
I hope help you with this, Good luck (remember rated this help).
Oct 13, 2009 | Jeep Cherokee Cars & Trucks
Boating Logo
260 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
