Question about HP Pavilion dv6000 Motherboard
I'm getting one long and two short beeps when I turn on my computer. HP says it's the video card embedded in the motherboard and therefore the motherboard itself has to be replaced at $425.00. Is there a cheaper solution? And I found that my wireless switch has a broken wire connection within the unit . Is it worth repairing this unit?
  • 245 Answers
Hi
Considering the age of the computer it would be cheaper to replace than buy a new board.
If you look on the label with the serial number,could youpost back the following?
Service Tag # right above the length of the warranty.
Part # right above the HP logo/Service Tag
Full Model # is there anything after dv6000 like letters or numbers?
I ask because I want to try and find a used board to compare the cost.
Thanks
Bob
Posted on Aug 20, 2010
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
I get continious beeping in my computer with no display
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
If you are getting hi lo beeps, refit CPU and heatsink
If continuous long beeps, check memory is seated correctly, if more than 1 stick, try each one on its own, 1 may be faulty, or incompatable
Aug 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
1 long and 5 short beeps
Check the video card and make sure it is fully seated. Check the memory chips and make sure they are fully seated. Usually the beeps are caused by bad/loose video card or memory.
Sep 13, 2009 | EliteGroup K7VMM Motherboard
One long beep followed by two short beeps.
That is a video error code. There is a known issue with nvidia/hp video cards. Suggest reading this for more info.
Jul 13, 2009 | HP Pavilion dv6000z Notebook
One long beep tow short beep
One long beep and two short beeps mean faulty video adapter.
If you are using a card, like a PCI or AGP video adapter then remove and put back the card in slot.
If you have a motherboard, then the video chipset on motherboard had gone, buy an agp video adapter and insert it in the slot inside your computer to fix the problem.
below an example of PCI and AGP video card:
MSI G4MX4000-T64 64 MB Graphics Card
HP Intel DVI AGP digital display card
ATI Rage 128 Pro 32 MB PCI Graphics Card
Mar 09, 2009 | Computers & Internet
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Computer beeps when I try to start up
No Beeps
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Beep code
The sequence of one long beep and two short beep when starting computer usually means problem in your display adapter. Make sure your VGA connector is connected properly to VGA out port.
If you are using VGA card (non on-board), you might want to make sure that the card is inserted properly to motherboard.
The beep indicates that system can not initialize display.
Dec 15, 2008 | HP Pavilion dv9000z Notebook
Computer will not boot
3 beeps = memory
long beeps = processor
long and short mixed = main board,,,
yours sound like memory, try the memory in another pc and see if it works
if it does its your processor
cheers
Jan 05, 2008 | AOpen AX34-U Motherboard
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
HP Pavilion dv6000  Motherboard Logo
96 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
