Question about Motorola Cell Phones
Often when trhying to make a call insgtead of the person I'm calling I get the messge of screen that says call restrictions sims -34 what is this can I get rid of it?
  • 712 Answers
Check if you have got enough balance on your phone to make a call. It seems that you are now running on negative balance.
Posted on Aug 20, 2010
Can't use phone, call out, get call restriction 34 message
see the link. Contact your telco.
Long after the fact, but in case someone searches for "call restrictions -34" info, as I did....
I called Tracfone Exec Resolutions Staff at 1-800-876-5753 and was helped very professionally by an agent. We found that the phone still identified with the first SIM card that I had installed, rather than the replacement I had installed in order to be in AT&T/Cingular network rather than T-Mobile. Within 15 minutes, he had walked me through entering one string of codes and a few parameter checks, turning on/off phone twice...I was then ready to go with a fully functioning Tracfone.
So, this issue can be resolved. Not sure if others problems will also be related to the SIM card issue, but it is a possibility. Hope this helps someone.
tracfone call restriction 34 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
Aug 9, 2009 - Why do I get tracfone call restriction message 34? ...tracfone call restriction message 34? I have a Motorola Tracphone with sufficient minutes, service days and charge bars. I have received call restriction 34 messages infrequently, but they have ... Question about TracFone® V170 Cellular Phone. 1 Answer ... Can't use phone, call out, get call restriction 34 message
12 Mar 2018
SOLVED: Tracfone call restriction 34
8 Sep 2014
tracfone restriction 56 Questions & Answers (with ...
13 Mar 2011
Why does my safelink phone say check call ...
4 Aug 2010
More results from www.fixya.com
Check Call Restrictions -34 (?!) - HowardForums
https://www.howardforums.com/showthread.../1529955-Check-Call-Restrictions-34-(-... May 23, 2009 - 13 posts - ‎12 authors
I got this message today - "Check Call Restrictions -34" - on a recently activated T101g which has only ever had 1 SIM (ATT). It also showed an icon for "out of your service area". I turned off the phone and waited 15 minutes. When I turned it back on, it had a signal & worked fine. I turned it off and back on a ...
What does the message--check call restrictions -34 mean and how do ...
https://www.justanswer.com > ... > Cell Phone Technician > Tracfone Problems May 25, 2011 - Hi, thanks for using. Technician's Assistant: that message appears if you have blocked any specific number of your contact list. It is not a Cell Phone problem, it's just the telephone Company is restricting the calls to your phone. You will have to contact your telephone company to check the Call restriction ... https://www.howardforums.com/showthread.php/1529955-Check-Call-Restrictions-34-(-!)
Mar 12, 2018 | Cell Phones
I cannot dial out on my samsung cell phone, I only get check call restrictions 34. On the screen it says no service.
Hi @Deloris Gosser , please check if you have a reception on the phone. If you do, please power off phone and remove sim card, put it back after a couple of seconds and turn on the phone and do a test. If still not working, please contact Samsung Support.
Hope this helps!
Oct 29, 2017 | Samsung Cell Phones
What is call restrictions-34
I believe that is international calling.
May 31, 2016 | Tracfone Wireless LG 440G
Can't use phone it says it has no sim.# n restriction 34 can u heip me
only your service provider can assist you with this . call them with someone elses phone .
Feb 12, 2016 | LG Cell Phones
I try to call my safe link phone says check call restrictions 34,how to I fix this!
Did you make at least one call per month on the tracfone? If not this maybe one of the reasons the call is restricted. You may have to manually receive your minutes for the month by: Pressing the menu key, when the prepaid menu appears press select. Go to redeem airtime or add airtime. If your screen displays a message scroll down and press ok until you see Card# or Airtime Pin. Enter 555 then press enter. If it says promotional code select no. Make sure you keep your safe link phone on to receive your minutes and see if that fix the problem. If that doesn't work you may have to call safe link at 1-800-378-1684.
Best Regards!
Feb 25, 2015 | Samsung Tracfone Sgh T105g Cell Phone...
Restriction 34
plug into computer and refresh software, check sim card, for corruption . replace it.
Jan 11, 2015 | LG Cell Phones
Restrictions 34
call carrier corrupt sim card??
Jan 11, 2015 | Cell Phones
The Samsung tracefone won't let me call out it's
Call restrictions are due to SIM card problems (Maybe you are using the wrong network, or your SIM card is not being detected by your phone) Another possibility is that your cellphone is restricted by the service provider. Why don't you give them a call?
Oct 25, 2012 | Cell Phones
Often when I try to make a call I get call restrictions sims -34 what is this and how can I get rid of it.
I will advice you remove the sim card from your phone and insert it in another phone, see if you the problem occur, if not, it means the problem is the sim tray on your phone. The sim try on your phone is bad, you will need to clean the sim tray on your phone and but back the sim to see if it fix the problem. I not, replace the sim tray.
But if the problem persist on the new phone you inserted your sim card, it means the problem is with the sim card, you will need to get a replacement sim for your sim.
Take care.
Aug 20, 2010 | Motorola Cell Phones
When I try to make a call, my TrakFone Motorola W175 g displays the notice "Phone restriction -34" and the call fails. I also can no longer receive calls.
Your sim card is bad in the phone. That is the most likely problem. Other than that the phone needs restored to factory settings and try again.
Jun 21, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Cell Phones Logo
46 people viewed this question
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
