Question about Husqvarna Garden
I have mowed for two hours and now it quit cutting. The belt is not off.
  • 24 Answers
Does it have an electric PTO? do you manually engage the blades or flip a switch?
Posted on Aug 20, 2010
My 160 has started having trouble mowing at its normal speed in my yard. I have not changed the height I mow at, or the frequency at which I mow... What's happening?
i am assuming you are talking about a john deere. if it has a lot of hours or is very old the drive belt may need replaced if you are talking about speed. if you are talking about missing some grass the deck belt may need replaced.
Aug 20, 2017 | Garden
Tip
What's the hurry
What's this marketing ploy now days about cutting your lawn mowing time in half. I can understand that if u have a bunch of lawns to mow. Beings i only have one, I'm really not a big hurry. Take a look at your yard, do some thinking, and don't over spend. I only want to have to sharpen 2 blades not 3 or 4, and the less drive belts the better. U get your exercise with a walk behind, and get the grass cut too. Last time I was mower shopping, one salesman tried to sell me a 6,900.00 lawn mower. He said it would cut my mowing time in half. I said I'm not buying a mowing that's worth more than my pickup, and for 6,900.00 I could pay someone to mow my yard, and cut my mowing time down to zero.
ballping
on Jul 29, 2010 | Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower will not go forward .... it runs .... and the deck still engages but will not move forward or backward
i would inspect the belt the mower and the trans operate from different belts
Jul 10, 2012 | Garden
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Belt slipped on the poulan self propelled lawn mower
The belt hopped off likely due to grass or other things getting in-between the belt and pulley near the blade. You should be able to remove the cover on the top of the mower deck, remove the belt from the pulley under the cover, place the belt back on the pulley near the blade and then on the pulley under the cover. If the belt is shiny on the sides or you see black powder caking the inside of the cover or area's around the pulleys or the belt looks like it has chunks missing from any part of it the belt should be replaced. local hardwares, automotive and DIY centers that carry outdoor power equipment parts can match it up with the one the manual recommends using.
Tip: Keep the blade sharp, I recommend buying a couple blades so that you can always have a sharp spare installed while the other is being sharpened, change the blade as soon as the sharp edge is gone and becomes somewhat rounded on the cutting edge. If the lawn produces a lot of dust or there are lots of bald patches this will dull the blade quickly as will chopping up stick with the mower, if this is the case take steps to improve the lawn and keep the sticks picked up before you mow.
Change the oil before using it in the spring and after each 50 hours of use (more often if its used in a dusty area).
I recommend using a synthetic oil unless the manual specifically states not to.
When mulching mow in counter clockwise circles, when bagging mow in clockwise circles and in either case overlap about 1/4 the width of the mower for a complete smooth cut. after each mowing allow the mower to cool then tilt the mower on its side opposite of the carburetor (where the air filter is) and wash off the stuff stuck to the bottom, you may have to use a putty knife on the real thick or stubborn stuff. This will reduce corrosion over the years and keep the mower running and mowing efficiently not mention it avoids blowing into the air backteria produced as the clippings of past mowing decay (it makes me sneeze).
May 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
CRAFTMAN LT 1000 no reverse
if it has a reverse belt it could be broken or sliped off the pulley
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
