Question about Samsung Digimax S730 Digital Camera
WHAT WILL I WANT TO DO WHEN MY POWER MODE OFF MY CAMERA WAS NOT CLASING ?
  • 466 Answers
As you would expect, this is not a good sign at all.
Probably, something happened to the drive train responsible for folding in the optics. Now it all depends on what the "something" was.
Start by ensure the battery is fully charged: you don't want to go haring for a hardware failure when the problem is only not enough juice to the motor assembly. Try getting the battery out, then in again, to clear some unlikely (but best try it first) electrical problems.
At this point we're most likely looking at a motor train failure.
If you hear a buzzing sound on power off, the motor is working but it's not gearing to the drive train itself. OR, it is engaging but there's a physical resistance foiling its operation. This could be caused by something (grit, sand, ...) between the telescope rings, or a small "overextension" or misalignment of the telescope assembly.
First the easy check: verify there's nothing between the telescope rings. Try gently working a corner of a plastic (not paper! if it shears inside, it'll worsen the problem!) sheet between the rings and check there's no obstacle.
If that was it, you're all set up. Enjoy your working camera.
If there is no dust, no sand, no grit, and yet it doesn't close, check the telescoping rings are axially aligned. If they are not, be very sure of which ring is the misaligned one and try twisting it back in the correct position. Do not overforce, and do not use tools; if you can't fix it with three fingers, a tool would only break it for good.
Third possibility, the rings are aligned but one of them, usually the one nearest the camera body, got "too stuck out". You may be able to fix it, at least temporarily, by gently pressing that telescope assembly ring in, with the machine powered on, and while keeping up the pressure, powering it off. I repeat, "gently". Forcing it won't help. With luck, your pressure will lock the gears against the motor gear enough to make it engage. How permanent the solution is, depends on why it went off-kilter. If it was a physical shock - it banged somewhere - you should be golden; unless something broke and provided it's not banged again, there's no reason why it should disengage again.
If the end-run block (sorry, I'm trying to translate as best I can) broke, then unfortunately the telescope assembly will disengage again the next time you power it on. You can't fix it permanently, it has to be unassembled and repaired.
Back to case zero: you power off the camera and hear no noise at all (except for a 'click' perhaps). The motor isn't running, so it either broke, or its internal connection is loose, or something triggered the end-run safety. Unfortunately you can't fix any of these conditions. Perhaps by pressing in and "rotating" the telescope assembly you might disengage the end-run, IF that is the problem, but there's a big risk of completely breaking the thing.
Other possibility: powering off the camera results in a clack-clack-clacking sound, like a plastic gear misengaging with another. That's probably exactly what it is - the internal drive train is broken or badly misaligned, most likely due to a physical shock (falling, etc.). There is no real chance of fixing it short of taking it back to the shop.
Posted on Aug 20, 2010
Will not power up in camera mode but does power up in playback mode
A failure to power up in camera mode indicates a problem with the lens. If the zoom or focus motors will not 'home' or 'initialize', the camera will continue to try endlessly.
If you mean that there is no picture but the camera runs otherwise normally (Beep, Start/stop, lights on, menu...), this is an Imager problem. Contact Canon about a repair. Canon may cover the repair for free.
Other things can cause it but this is most common.
Mar 22, 2010 | Canon ZR40 Mini DV Digital Camcorder
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
Sony DSC-P73 auto power off in picture mode
Hello!
You may try using any another compatible Battery pack in the Camera to ensure if the issue is not causing due to the Battery. Actually, when the Camera is switched to the "Picture or Camera" mode then the power consumption increases spontaneously. So, if the Batter is not holding sufficient charge to cater the power need of the Camera in the Camera mode then it'll automatically turn off. However, if the issue persists with spare Battery also then you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds. Otherwise, it's required to get the Camera to resolve the hardware issues.
Aug 21, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
I have a Canon camera, which worked fine. I had to recharge teh batteries often, that was all. Last night, i took it out. In view mode, the camera does not shut off. The moment i switch to camera mode, the...
I'm assuming you're talking about a point-and-shoot model, and not the 1000D as the category suggests. Camera mode has significantly higher power requirements than viewing mode. It is possible that your rechargeable battery has degraded to a point where it no longer can power camera mode, or it might just be discharged. Try with a freshly charged battery, or if you're lucky enough to run on AA batteries, get new ones. You might also try using the camera while plugged into the USB port of the PC, which might be able to supply power to the camera. I have noticed that when the batteries are near-empty, the camera "dies" rather abruptly.
Jun 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Powering off
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Erratic Printing
I had the same probleme, norten anti virus was clasing with the hp software. I suggest that if are using norten uninstall norten and see if this makes any differance. There is a special norten uninstall application called NO NORTEN.
Apr 26, 2008 | HP LaserJet 1020 Printer
Power Wont stay on when in Camera mode
I have the same problem. Can anyone help please?
Dec 23, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
Power turns off
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Mar 01, 2007 | Casio Exilim EX-Z500 Digital Camera
The camera does not take a photo when I press the shutter button. What should I do?
Check the following: * Make sure the battery or batteries have power and are correctly installed. You may need to replace the batteries. * Make sure the power is on. The camera may have turned off automatically to save power. Press the POWER button to turn the camera on. * Make sure the Mode dial is set to the correct mode. The shutter button will operate when it is set to Manual mode, Automatic mode, Continous shooting mode and Video mode. * Check the number in the lower left corner of the Camera’s LCD screen. If the number is 0, the memory card (or internal memory) is full. Copy the photos to a computer and delete them from the camera.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Samsung Digimax S730 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
