Question about Dell (8N816) Motherboard
The light on my hard drive is yellow rather than green and my computer will not turn on.
My Dell tower turns on with the power button's light as yellow . The fan runs then, after a couple minutes, Stops.
Posted on Jul 29, 2012
  • 466 Answers
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Posted on Aug 20, 2010
The hard drive does not "power up". The green
I'm assuming this is a USB external drive. It's likely that the drive is failing, but to find that out for sure you'll need to remove the actual hard drive from the housing, insert it in a computer as a slave drive, and run a diskchk on it to see if it's responding correctly. If that test is successful (ie., it tests OK and you can access the drive as a slave in another computer) then it's just the USB interface on the housing that's bad. You can always just get another housing (they're inexpensive and lots of them).
Hope that's helpful.
Jan 12, 2011 | LaCie (300703EK) 250 GB Hard Drive
I have a compaq presario sr1503wm.There is a green light by the power button and a much smaller green light below that.Sometimes this light turns yellow.what is it?and whats it do?
this may be the battery light or Hard drive light.
Usually if the light is green then yellow this is an indicator of the low battery.
Mar 31, 2010 | Computers & Internet
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Wont turn on?
The external have a problem it need to be repaired or just buy new
Oct 28, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Yellow light?
Tre, save early, save often, save many. I have seen, heard and experienced external hard drives failing. It is a good habit to use the "usb device safe removal tool" the green arrow on the task bar. When the device is safely removed, turn it off. When you need the drive again...turn it on save files, safely remove device, turn it off. Sometimes the turning on and off of the computer with the drive hooked up can cause issues over time. Anyway hope that helps. Good Luck. Tim
Mar 14, 2007 | Fantom Titanium Hard Drive
Dell (8N816) Motherboard Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
