Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
I can not find my manual and I'm trying to clean my oven with the self cleaner. This is an accubake. I press self clean button and hit start. After a few seconds E1-F5 comes up. Do u have a sheet on how i can self clean
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%TE
Posted on Oct 01, 2010
SELF CLEANING INSTRUCTIONS FOR WHIRLPOOL SUPER CAPACITY 465 ACCUBAKE
It's best to remove the racks. However you can go on line to download a free manual.
Dec 31, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I spilled a lot of bacon grease in my accubake oven when i turned the self cleaner on it flamed
Wipe out the oven with paper towels. As much as you can. Try putting some baking powder down to absorb the grease then wipe it out. If the flames are not huge it should be ok. Mine did that once and burned out the grease and did not damage the oven, but they were very small and burned down quickly.
Aug 10, 2014 | Whirlpool Accubake RF362LXTT Electric...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    I am trying to self clean my Whirlpool stove/oven. I keep getting E1-f5 on the control panel. HELP, my oven is dirty~
    use easy offoven cleaner. when using the self clean feature the oven gets so hot that it's likely to burn out some of the electrical components
    May 20, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
    Describe how to access the self cleaning feature on the accubake oven and how long does it take?
    Press the "Auto Clean" or "Precise Clean" button depending on the control type of your range. Then press start. The oven should lock and start the self-cleaning cycle. The cycle is usually 3 hours from start to finish and cannot be stopped once it has started heating. The range gets extremely hot and causes the inside of the oven to act like a catalyst to burn the grease. It will create smoke and odor depending on how dirty the inside of the oven is. Make sure to leave the exhaust fan on above the range to remove some of the heat. And definently do not do the cleaning cycle on a hot summer day!
    Feb 19, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
    I was self cleaning mt oven and now it stays locked , and displays a code of e1 in red on left side of display and f 5 on right side of display whirlpool self cleaning oven with accubake system
    I pressed the start button for 5 seconds and the lock symble came on than I pressed the start button again for 5 seconds and the oven unlocked and all is well
    Jan 07, 2010 | Whirlpool Ovens
    Whirlpool Flat top Accubake self clean 24 inch
    Of course - Empty the oven and clear off around it.
    The AUTO-CLEAN cycle time is adjustable, from 2 hours
    30 minutes and 4 hours 30 minutes in 15-minute increments.
    Suggested clean times are 2 hours 30 minutes for light soil and
    4 hours 30 minutes for heavy soil. The last 30 minutes of the
    cycle is for cool down.
    To Self-Clean Using AUTO-CLEAN
    1. Press AUTO-CLEAN.
    2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
    desired self-clean cycle time.
    3. Press START.
    The oven door will automatically lock. The “DOOR LOCKED”
    and “CLEAN” indicator lights will be displayed. The time
    remaining will also be displayed.
    4. When the self-clean cycle is complete and the oven cools,
    the “DOOR LOCKED” and “CLEAN” indicator lights will turn
    off.
    5. Once the oven is completely cooled, remove ash with a damp
    cloth.
    To Delay Start Self-Clean Using AUTO-CLEAN
    2. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired self-clean cycle time.
    3. Press START TIME.
    4. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired start time.
    5. Press START.
    The oven door will automatically lock. “DOOR LOCKED” and
    6. When the self-clean cycle is complete and the oven cools,
    off.
    7. Once the oven is completely cooled, remove ash with a damp
    cloth.
    Owner, Warranty, Installation and Parts manuals are here:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
    Sometimes search links don't work when copied.
    Here is the direct link to the Use and Care Guide:
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
    Page 16 has the above instructions.
    God Bless!
    -Ptochos
    Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
    Oven wont work after self clean
    I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
    Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
    Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
    220 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
