Question about Mtd Garden
Mtd mower melted wiring harness thought i fixed the cause but as soon as i hook up the battery on new harness it blows the fuse
  • 718 Answers
You have shorted something out, trace wiring with volt meter.
Posted on Aug 21, 2010
Having trouble with the fuse blowing...what could cause this?
need to look at wire harness and such start from battery forward or from switch to solenoid and look for debris /chaffed or loose broken wire but check starter may be hanging up and blowing fuse
Aug 01, 2016 | Garden
What will cause both battery cables to melt on mower?
Sounds like you hook the new solenoid wrong. Like postive to ground.
Mar 17, 2014 | Mtd Garden
John deere z425 mower blows fuse for charing system
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 30, 2012 | John Deere Garden
I have a cub cadet mower 2166, It wont start it keeps blowing the red wire fuse, I thought it was the battery so I bought a new one and cleaned the cables and ground wires, and I didnt see any loose or...
There is a wire shorted to ground (metal) somewhere...check all the wiring for a bare spot somewhere... this is causing the short...repalce the wire and you will be good...
finding the bad spot is the hard part...
heatman101
Aug 13, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Ecmb fuse blows as soon as i put in a fuse without keys in the ing.
hi, i have seen this problem before, i am a trained ase mechanic who works in a shop weekly. in my case, the suburban was a 91, it started by blowing the fuse randomly, then as it got further along, the ecm b fuse would blow consistantly as you describe. I found the problem to be in the wiring harness between the fuse block and the electronic control module on the pink/black power wire. It had become hot next to the radio and the insulation had melted into a direct ground to the ecm. then as time passed, it melted six other wires till it hit battery power. this is when it shorted the fuse all the time with key in or out. You should start by checking behind the glove box at the wiring harness going into the ecm, if you can get a schematic for the wiring, it would be better advised. See if you can find the Pink and black stripe wires(there maybe several of them as they power everything from egr solenoid to oxygen sensor possibly) and look for melting of the insulation. If you do find this to be the case, technically you should replace the whole harness, but it is possible the cut and splice in new wires. If any other wires are affected, you should replace these also. Check the whole length of the affected wires, they may have shorted all the way up or down. If this sounds like a big deal, it is! so, good luck, hope this helps.
May 10, 2010 | Chevrolet Suburban 1500 Cars & Trucks
I have a five year old JD L110 garden tractor that just started blowing the inline 20 amp fuse that is directly connect to the positive side of the battery terminal, when the fuse blows it melts the entire...
need to ohm out the clutch....clutch ohms are 2-4 ohms anything less will blow the fuse due to it being shorted out,,,,,takes less than a min to find out with a multi meter
hope this helps
Nov 21, 2009 | John Deere Garden
Yardman 17HP lawn tractor blowing fuse when key is turned
Any time a fuse blows there is a direct short to grown. Fuses only work in a hot wire. Some where there is a wire hot wire with a bare spot touching the frame or another ground wire. The seat could have a wire pinched, the motor may have melted a wire or something simple like that. Move all the wire around and see if they may be pinched or touching another wire or it any are melted together.
Aug 16, 2009 | Mtd Garden
How do I check an ignition switch (691641) to see if it is bad
IF YOU TAKE THE STARTER SWITCH OFF AND TURN IT OVER IT IS MARKED + POSITAVE _ NEGITAVE AND SO ON
Jun 12, 2017 | Mtd Garden
Mtd mower blows fuse when you try to start it
Pull the starter and have it bench tested. If it is ok then you may have an engine timing problem. ''Good luck. donnyb60
Mar 23, 2009 | Garden
Garden Logo
131 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
