Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore HE3T. Larger/Heavier loads are no longer coming out as spun-out as they used to - they are spun out, so they're not dripping wet, but they are not nearly as spun-out as they should be/used to be. I am now forced to take half the load out at the end and spin it on it's own drain/spin cycle. Not looking for an answer of "lessen your load size" because the machine never had an issue before with this at all in the past - that is the key point = something has changed and I need to figure it out. The machine does NOT error code out, and it does spin fast, just not full full speed or as long as it used to. I watched one full load on drain/spin spin up kinda fast, then the timer suddenly dropped from like 13 to 1 and the drum slowed down and then stopped. It just won't spin at full speed. And the load is not out of balance. I am stumped.
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
Got a Kenmore Elite HE3t Front Load washer from my old man, hasn't been used in 5 years... sat in my basement for the first month i lived here unhooked and unused... FINALLY, got a dryer, hook everything...
A burst hose or a broken hose connector clamp most likely. Open the back after disconnecting power. Use bright flashlightto see where its dripping from and confirm the hose-clamp is brokem/ open or a connecting hose is burst. Carry broken hose to hardware store like Rona for a replacement tubing, cut to size and re-instal, voila!
Dec 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Apr 17, 2009 | Kenmore Elite 45986 Front Load Washer
Excessive Shaking
Possible solutions... level, if on pedestal, make sure its tightly secure to washer, wash like size materials, larger items might wrap smaller items causing a ball or heavier on one side.. good luck.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Alll the water does not spin out , clothes still wet
Your clutch is wearing out and needs to be replaced. It will only get worse. Ive included a schematic , part # is 285785. #5 on the schematic. Let me know if you need more help, thanks dave www.washermd.com
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore HE3t water fills by itself! with door open too! doesnt always drain fully
If you tip the machine back at an angle, you should see a clear plastic sausage shaped thing with a plastic tube coming from it, you will need to remove the plastic thig (pressure vessl) and clean it out.
Nov 30, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
366 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
