My eee pc was suddenly shutdown and it doesnt come up again
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Posted on Aug 20, 2010
Problem with ASUS Eee PC 900 PC Notebook I replaced the LCD screen on a Eee pc 904ha and now the back light wont work
this means that the inverter which is used to backlight the screen is not working. Check again all connections of the LCD. It is very common to brake the inverter cause it is very fragile. If checking the connections doesnt help i think you should try changing the inverter, it is low cost. Check e-bay for a converter.
Sep 18, 2011 | ASUS Eee PC 900 PC Notebook
My 900hd netbook won't boot
as soon as you turn your netbook on, keep tapping F8 until another screen pops up, then select start up repair, If no problems found and doesnt work. repeat the process but choose safe mode with networking, then click start and shutdown, try and reboot as normal, If doesnt work. Select safe mode with networking once again by repeatedly tapping F8 as soon as you switch on your netbook. Please download tdsskiller.exe (exe not the zip) to your desktop using this link at the end. Once downloaded please double click to install. Once installed open and run a scan, once scan complete, select cure and then rebsart your system, start system normally and that should solve the problem http://support.kaspersky.com/viruses/solutions?qid=208280684
Please rate if helpful, thanks. P.S tdsskiller is a freeware and will not cost you a penny.
Mar 10, 2011 | ASUS Eee PC 900HD Netbook
How to reboot my eee pc 1005ha
go to start in windows, then click on shutdown, then restart.
If thats not possible, hold down the power button on the laptop till it shuts off, then press it again to turn it on.
Feb 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
ASSUS eee pc 1ooo H doesnt start from time to time !
do you have it set to hibernate check that setting ...the whole on the bottom is the reset switch for the machine
Nov 19, 2009 | ASUS Eee PC 1000H Laptop
My eee pc is not turning on at all
If it doesn't boot AND you have some light on BUT it never displays anything on the screen, THEN, taking out the battery, wainting 15 seconds and then assembling it again might make it work.
May 02, 2009 | ASUS Eee 4G Notebook
EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Nov 25, 2008 | Konica Hexar Silver 35mm Point and Shoot...
Suddenly shutdown
Hi.
Try formatting your pc.
Maybe this will help.
Tell me if you still have a problem.
Oct 13, 2008 | Fujitsu AMILO D-7820 Notebook
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
