Question about Canon Elura 80 Mini DV Digital Camcorder
Zoom button is malfunctioning
Zoom will not stay set and changes when button is released. It zooms very slowly out to the wide angle setting and automatically returns quickly to the max telephoto setting when the button is released.
Why is it happening and what can I do about it?
  • lennyngee Nov 02, 2008
    Mine does the exact same thing!
Tons of people w/ any canon elura series cameras including myself, with a canon elura 80 have the same zoom problem. It does not appear that canon has done anything to try to solve this mass problem with this series of cameras. Oddly enough the only way to solve this problem is to give it a tap and gentle hits near the zoom button to release what would seem to be a jam. Sorry that there's really no straight forward answer, but for now its the best i can give.
Posted on Jun 08, 2008
Canon 380ex
I had a similar problem with my 430 EXII flash recently and discovered that after using the flash head in a "bounce" orientation, where the zoom automatically sets itself to 50mm, It wouldn't go back to wide angle or telephoto when I folded it back into place. The problem was caused by a small piece of confetti preventing the head from fully resting in the forward position. Check to see if there is any debris caught in there.
Dec 15, 2013 | Canon Cameras
Focus out problem in canon 50d while using 24-70mm lens?
If by a "normal" lens, you mean a 35mm or 50mm fixed focal length - often called "prime" lens, that is to be expected. The additional and internal rotating optical elements all contribute to loss of clarity, color loss, and increased chromatic aberration that starts to become noticeable when compared to use of a prime lens. It's a trade off; less number of lenses to carry and lower cost when using wide angle zoom lenses as opposed to a prime lens for even just a few of the focal lengths offered by the wide angle zoom types.
You can minimize the unwanted effects by staying away from both the extreme wide angle and zoom focal lengths as well as the widest aperture settings. If you can stay 2 or 3 stops smaller from wide open, you can limit these destractions from your pictures. This is recommended advice for nearly every lens: Keep away from the extremes.
Jan 08, 2012 | Canon 24-70mm f/2.8 Lens
I have a Nikon 40x and whenever I zoom in to take a picture, the picture is blurry. However, when the camera is zoomed out all the way the picture is clear. How can I fix this? Or is there something wrong...
Probably because at the longer end of the zoom range you are getting camera shake. On the wide angle setting shake will not be nearly so noticeable. Use a tripod for long telephoto shots or practise squeezing the shutter release really gently-like the trigger on a gun ;-)
Apr 22, 2011 | Cameras
My zoom seems to be froozen.
there is a switch on the front of the camera (by the lense) that says manual/sevro, turn it to sevro and your zoom button should work again.
(obviously when it's set to manual you need to turn it by hand)
- do not turn it by hand when it is set to sevro because it's bad for the motor
Jun 26, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
SB-600 Power Zoom stuck at 14mm
I struggled with this one but then, on the basis that if all else fails read the manual I found the answer. It's soooo simple. The wide-flash adapter is set. That's the little pull-out screen at the top of the flash which folds down over the flash-head. If it's pulled forward it activates the wide angle setting automatically. Push it back in and you'll be fine. tony k
Dec 16, 2008 | Nikon Speedlight SB-600 TTL Flash
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Canon Elura 80 Mini DV Digital Camcorder Logo
226 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
