Question about Akai Mpc2500 Music Production Center
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
I went to new file to create and rename once I hit f 5 or enter the mpc froze and I couldn't do anything,the mpc saved the name but can't open on computer it say's my file is corrupted or unreadable
Posted on Aug 31, 2010
    President:
  • 1,138 Answers
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Posted on Aug 24, 2010
Which system do I need to be able to trigger loops/textures/pads from the lower 2 or 3 strings of my guitar (kinda like one finger accompaniment on cheap keyboards), while soloing on the higher strings?
You could hook the output of the GR33 to something like an AKAI MPC (http://www.akaipro.com/mpc) assigning different notes to trigger different samples or sequences.
Sep 19, 2011 | Roland Gr33 Guitar Synthesizer
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
When I have my instrument cables coming out of the stereo outs of my mpc 2500 but it out come out mono. I don't know how to make it come out stereo. Is my mpc 2500 broke
To get stereo you must record in stereo or "PAN" individual inputs to one side or the other to create seperation. Your device is NOT broke.
Read your manual about panning.
Aug 04, 2010 | Akai Mpc2500 Music Production Center
I have an older mpc 1000 & just today it started changing the programs & number of bars of the sequence I was making when I pushed the cursor.
There is probably a switch problem. IF these use the conductive rubber contact type switch buttons where a "pill" of conductive rubber is pressed onto a circuit board with traces, CLEAN the contact rubber AND the circuit board with 99% isoprophyl alcohol and Q tips. This type buttons feel "Rubbery and squishy" when pressed.
If the buttons have a hard tactile feel, then check for a bad button that might have broken internal parts and replace it... OFTEN you can tell by the "feel" when pressing compared to others.
In either case, disassembly and service is required.
May 12, 2010 | Akai Mpc1000 Music Production Center
Os update promblems mpc 2500
Try this site:http://www.akaipro.com/mpc2500 Try downloading all the the release notes for ver.1.24 if you haven't already. Download the ver.1.24 which seems to be the newest to your computer first and install from there. It might have gotten corrupted the first time you tried it. You will have to email them using the form for the newest release notes and the installation instructions:http://www.akaipro.com/mpc2500 http://www.akaipro.com/content1924.html and http://www.akaipro.com/mpc2500 are the URLs you need. Hope this helps.
Apr 16, 2010 | Akai Mpc2500 Music Production Center
Mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Jan 21, 2010 | Akai Mpc2500 Music Production Center
Akai Mpc2500 Music Production Center Logo
317 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
