Question about Cameras
I dropped my Nikon Coolpix S230 camera in water. What can I do?
  • 95 Answers
Try removing the battery and placing it in a sealed container with rice or silica packets (like you get in shoes) for a few days to wick the water out. If that doesn't work you're most likely out of luck.
Posted on Feb 18, 2015
  • 11967 Answers
SOURCE: my nikon coolpix s230 wont flash, is there anyway
Have you accidentally turned it off? Is there a picture of a lightning bolt with a line through it on the screen?
Posted on Dec 20, 2009
  • 11967 Answers
SOURCE: nikon coolpix s230 lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 19, 2010
  • 102366 Answers
SOURCE: My nikon coolpix s230 won't charge, it's connected
Connecting the S230 to a computer does not charge the camera; instead it drains the battery as the camera communicates with the computer. You need to take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
Posted on Mar 15, 2010
SOURCE: nikon coolpix s230 shows lens error
please i need help! im only 12 years old and me and my friend were going to put a video on youtube of us singing and then i accidently dropped my nikon coolpix touch s230 on the floor and it wont let me take any photos or vids and is saying "lens error!" i pushed the lens in like a dummy and is really broken. how much money will it cost to get my lense fixed!
Posted on Jul 09, 2010
  • 102366 Answers
SOURCE: how do i change the
Tap MENU to bring up the menu screen. Tap the wrench icon to bring up the setup menu. Language is the eleventh item on this menu.
Posted on Nov 22, 2010
I want to know service center of nikon here in manila. my digicam fell. and now once i open it is just clear and it has crack on it.
to know service center of nikon here in Problem with the Nikon COOLPIX S230 Digital Camera
visit this site http://newsallworld.com/
or
http://www.addsterms789.blogspot.com/
Jul 18, 2011 | Nikon COOLPIX S230 Digital Camera
I lost the cd for my Nikon Coolpix S230 and are looking for a free download.
You can download the current version of all (free) Nikon software from http://support.nikontech.com/app/answers/detail/a_id/61
May 19, 2010 | Nikon COOLPIX S230 Digital Camera
My nikon coolpix s230 won't charge, it's connected to the computer, but it's not doing anything.
Mar 15, 2010 | Nikon COOLPIX S230 Digital Camera
It is possible to transfer videos from my camera nikon coolpix s230 to my pc ?
Hello. Yes if you can transfer pictures you can transfer video,however you'll need a program to play them back(Quick Time from apple is free).Heres a link to Nikon for the user guide.Look on page 93 for computer connection instruction.
http://support.nikontech.com/app/answers/detail/a_id/16313/~/user's-manual---coolpix-s230---guide-to-digital-photography
builderdale
Jan 17, 2010 | Nikon COOLPIX S230 Digital Camera
Nikon coolpix s230 shows lens error. will not take pic or shut off
Dec 29, 2009 | Nikon COOLPIX S230 Digital Camera
"Lens Error" on Nikon Coolpix S230
Sorry, but there's no simple DIY fix, and any homebrew repair attempts will likely make the damage worse. Your camera's warranty won't cover the damage, so I suggest that you take it to a local camera shop (NOT the camera department in a chain store) or contact customer service via the nikon.com web site to arrange repair. Be sure to get a firm price before you commit to anything though. The fix can easily approach the price of a new camera, and repairs typically only carry a 30-day warranty.
Dec 28, 2009 | Nikon COOLPIX S230 Digital Camera
My nikon coolpix S230 was dropped when the lens was out and now it just says lens error and the lens wont go in.
my nikon coolpix s230 was dropped with the lens out and no it wont go in either. in the inside of the lens a piece of plastic was forced in front of the lens that takes the picture. The warrenty will return and exchange my camera. Good Luck with fixing you camera! Im glad im not the only person this happened to !
Nov 02, 2009 | Nikon COOLPIX S230 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
